Hi Daniboun, thanks! I have no worries for soldering, I already have some diy pre amp experience.( first watt acp+)
I am wondering if sound quality will remain mostly intact, using the single ended route
I expect you will need to get panel mount TRS Sockets, connected to the board with wires.This is great, then.
Looking for TRS female socket to fit exactly the 3e board, the same with the XLR used here (3 long-toothed pins to be soldered).
I doubt though that any difference will be audible.In my humble opinion this will undoubtedly impact Sinad. All you have to do is see the tests of the other PFFB amps measured by Amir. When I spoke with 3E Audio before conceptualizing my project: he told me to use this module in differential mode....
I don't think you can solder TRS connectors directly to the board. If you look at the photo in the original review, the TRS connectors are also panel mount with wires to the board.Though I am thinking to go with the XLR sockets as long as TRS to XLR works fine. XLR is increasingly offered on DAC's and streamers, so it will be future proof. Not leaving aside SQ, which is why I embarked in this DIY adventure.
Can I have a close photo to check exactly how the 3 XLR pins fit and are soldered to the board ? Does this require additional parts, other than soldering ?
That is a PCB mounting connector but the PCB doesn't have the holes to accept it.Maybe I am confusing you with my lay approach.
Finally I am thinking to exact same XLR socket as listed in OP:
NEUTRIK NC3FAH-0 Embase XLR Femelle Plaqué Or pour PCB - Audiophonics
Le Neutrik NC3FAH-0 est une embase XLR 3 pôles femelle avec contacts plaqués or et pin de mise à la terre séparé. Elle permet un montage aisé sur PCB.www.audiophonics.fr
My question is how are these fitted ? soldered ?
So this one is better as it is combo + has the right terminal pins for the board. Great.Get a combo XLR / TRS plug and that s it )
I will share you the wiring diagram )
Neutrik NCJ5 FI-S
Embase combo Combo jack 6,3 mm mono / XLR 3 points, Norme D, À souder, Vis adaptées disponibles en option, article n° : 300310www.thomann.de
The one example I have seen (fosi v3 mono measured by amir) shows 6db more noise because the gain is 6db more. I don't know where the substantial fall in sinad is.I am not talking about audible difference )
I'm just saying that this will lead to a substantial fall in Sinad...
No, it has solder lugs for wires. There are no connectors that will solder directly into the board.So this one is better as it is combo + has the right terminal pins for the board. Great.
Thanks for the clarification. Somehow I am confident I will go for it, though no nice cases , most probably I will keep them all separated.No, it has solder lugs for wires. There are no connectors that will solder directly into the board.
