Why would I ask another vendor about this amp? Again, your comments are inappropriate and of zero utility.
Ok.
Yes, you have it right. I am not aware of a specific standard using 4 Vrms (not that I have looked hard). For many years standard levels were -10 dBV ().316 Vrms) for consumer products and +4 dBu (1.228 Vrms) for professional products. Higher output voltage from DACs has become popular IMO to provide ever-higher SINAD/SNR numbers. They are typically limited by their noise floor so higher output voltage provides better SINAD (or at least SNR) numbers.My 3 channel NCx500 amps have arrived at long last.
Here's a question...The variable gain is given as:
*Gain settings, if using the Buckeye buffer stage:
4ohm - 24.2dB/3.2Vrms (High), 19.2dB/5.8Vrms (Medium), 14.2dB/10.3Vrms (Low)
8ohm - 24.2dB/3.4Vrms (High), 19.2dB/6.0Vrms (Medium), 14.2dB/10.8Vrms (Low)
*Gain setting, if using the Hypex onboard buffer stage:
4ohm - 26.8dB/1.88Vrms
8ohm - 26.8dB/1.95Vrms
Curious, since this amp has XLR inputs, and my understanding is that the standard for such is 4Vrms, why there isn't a gain option that matches? Seems with my Octodac, which outputs the standard 4Vrms, I can either choose the High setting, and take care not to go near full output on the dac, or go to the Medium setting, and not have access to full power. Do I have that right?
Note using the 8-ohm numbers and your 4 Vrms DAC's output, 3.4 Vrms on the high setting is a difference of -1.4 dB, so you would only overdrive by 1.4 dB max. That is a pretty small overdrive. If you choose the 6 Vrms setting, then you give up about 3.5 dB in headroom (or max output), a little over one-half the power. I would use the high gain setting if noise is not an issue. What are you using for a volume control? I would normally expect a volume control within the DAC or between DAC and amp, and would be surprised if you drove the amp to near maximum output in a typical listening environment (i.e. had the volume all the way to max).
HTH - Don
Thank you very much for a very useful reply.Yes, you have it right. I am not aware of a specific standard using 4 Vrms (not that I have looked hard). For many years standard levels were -10 dBV ().316 Vrms) for consumer products and +4 dBu (1.228 Vrms) for professional products. Higher output voltage from DACs has become popular IMO to provide ever-higher SINAD/SNR numbers. They are typically limited by their noise floor so higher output voltage provides better SINAD (or at least SNR) numbers.
HTH - Don
To tell the truth the obvious choices should be 2,4 and 5V as that's what the majority of today's devices output.
On the other hand I like the 10V one.
Hope my order is in there somewhere, and ships soon... Very exited!Another large batch of the 2kW SMPS' have arrived and will be filling pending 2023 orders for the 3ch NCx500.
My hope is to have all 2023 orders for the 3ch NCx500 filled within the next 2-3wks (mid March goal).
Then we will be working on the 2024 orders and finally carrying a consistent inventory of the SMPS so there will no longer be back order delays.
In my case my LRS sound amazing in my room. I just wonder is I'm missing out with the Parasound hca 1500a vs another amp like the Ncx500.No matter how much power I put to my Magnepan LRS they sounded like a tiny bit of reverb was added to the music and lacked definition. I got rid of mine and went with Revel. That's probably not what you are looking for but it really improved my listening sessions. The Revels offer superb definition and punch that my LRS couldn't provide no matter which amp I used. Buckeye amps didn't change that in my listening room.
I realize those LRS love power, but assuming your Parasound is not choking on the easy phase angle but sometimes 3 ohm load of these speakers then I doubt you would notice a difference - specs on the Parasound show 315 watts into 4 ohm stereo.In my case my LRS sound amazing in my room. I just wonder is I'm missing out with the Parasound hca 1500a vs another amp like the Ncx500.
Now all we need is the 14" SpeakOn case!Another large batch of the 2kW SMPS' have arrived and will be filling pending 2023 orders for the 3ch NCx500.
The power draw is not due to the NCx500 modules but the the power supply. With our input buffer board, originally designed using the Hypex SMPS1200 series for Purifi builds, we did not have a proper design/pinout in place to handle the Micro Audio SMPS Standby feature.
As some of our 2024 overall product improvements, we are going to be trialing a simple change to enable Standby control.
Please keep us posted. Thanks.It will be, yes. But no timeframe/ETA. It is part of something that will be tested and implemented as we slowly work on incorporating Micro Audio SMPS' to more of our products in place of many of the Hypex SMPS' options.
Dylan,
I got my 3 channel amp a couple of days ago thank you very much.
With no input signals and no speakers or loads connected I plugged it into an ac line Watt measurement device to see what the various off/idle power levels were. I measured the following results:
On............................38 W
12V trigger Off........21 W
Auto/Idle...................21 W
21 W while "off"/not doing anything seems a bit high. Is this normal for the NCx500 modules and/or the 2000 W power supply?
If you never play music the above comes to 21*24*365 = 184 kW-hour which at $0.25/kW-hour cost of electricity in the Boston area comes to $46 per year just to have this device plugged in.
Europe we had already above 50cent/kWh .. it settled a bit, but in average we are above 35cent/kWh in GermanyDylan already answered the amp power aspect but was pretty shocked by your rates. Am paying about $0.11 here.
Is that just the generation cost or something more?
