HiFiDiscoveryTrip
- Joined
- Dec 26, 2020
- Messages
- 33
- Likes
- 22
This is wrong.
It depends on the plastic and how you price it but, by weight, plastics are mostly more expensive than metals.
If you are going to produce a very large number of items making them in a plastic material may work out cheaper since if you have the volume to justify the (high) cost of tooling the piece part manufacturing cost can be very low indeed compared to making the same part from metal, but that is because of manufacturing cost, not material cost.
Next some fibre reinforced plastics are the highest cost and performance engineering materials we have.
The acoustic properties available will depend on the detail design but there is no reason at all why a "plastic" speaker enclosure can't be first-class technically.
Thermo-set plastics reinforced by appropriate fibres (there are many choices) are horribly expensive but produce, IME, the best properties of all materials I have used.
@preload I follow your reasoning entirely. Probably the comment was also incomplete and generalised.
Carbon fiber reinforced plastic as used by Wilson Benesch, for example, is very good, but the advantage comes from combining it with other materials. The different resonance frequencies of each material make the cabinet more inert and therefore less of a loudspeaker in itself.
This production process has no comparison with the injection-molded plastic like the KEF Blade.
One can also wonder about the impact of mounting large bass drivers in such a plastic cabinet. The forces cancel each other out by their arrangement, but still. Especially when they are mounted relatively high in the cabinet, as is the case with the Blade.
The reason why I doubt why injection-molded plastic is ideal is because renowned brands like Wilson Audio & Magico do a lot of research on this. Wilson Audio uses for their top speakers another cabinet material for the tweeter, mid-driver and bass-speaker. Seems logical because each driver operates within a different frequency range which triggers different resonance frequencies.
