Sadly things are not going well with the new amp.
First impressions - and I've not even got to listen to it.
On the + side:
1. The build seems solid, the surface treatment is very anti-fingerprint. Yay!
2. The front panel light is actually a pleasant white halo, but still ought to have an option to turn it off.
3. Nice enough fabric protection bag inside the final box and it came double-boxed.
On the - side:
1. There seems to be an additional large blue LED on each of the modules, visible through the slots in the case, probably not Audiophonics fault as they likely come on the 1ET400 modules. Purifi should use a tiny, not too bright SMD one if they really think they need it. Can it be cut off and not ruin it/void the warranty.
2. With the processor turned off, the very low level of tweeter hiss is almost gone, but with the SSP on, the tweeter his is still very obvious and just reduced a little.
This could be because the gain is set to the highest option, I did ask for it to be set to "Trinnov Altitude 32 compatible" and that note is on the invoice I was emailed, however there is no indication as to if this was done and if so, what it was set to, maybe I should have requested "bypass" but again, no documentation as to what it was set to at all.
3. No user guide of any kind, even a single A4 sheet with pics of the connections (for newbies) and stating the gain that is set or the jumper settings would have been nice to see.
4. This is where things get unpleasant; they have chosen to use some really tiny (2.5mm?) hex head screws to hold the case on and of course I don't have the right bit and don't want to use a suitably sized flat-blade screwdriver. Torx would be much better - and of course I have a set of those. Thus I can't get the lid off to check the gain settings. Doh!
5. Some softer feet would be nice, they are very hard plastic and could perhaps scuff the top of anything delictate (like other hi-fi gear) they are placed on.
So it's off to Amazon for maybe a Sunday (earliest) delivery of some hex bits to see if it's on a higher gain setting and hope it is an moving to bypass fixes the hiss.
No where was that post with the jumper settings ... I couldn't see them on the Audiphonics product page...
Got to love this "hobby"!
