Was the Audioholics review not based on the older AKM DACs? (or did Audioholics test with the latest ESS DAC being used?)
I don't know that for sure, but I would bet the tested unit, done in 2022, would most likely has the ESS, model ES9010K2M. The shortage of the AKM chip would have been serious by then, as D+M, Onkyo would have switched away from the AK4458 long ago.
Regardless, the specs of the AK4458 and the ES9010K2M are incredibly close so I see no reason why they would perform much different on the test benches.
SINAD: AK4458..107 dB, vs ES9010 K2M's 106 dB, and for SNR: AK4458's 115 dB, vs ES9010 K2M's 116 dB.
If that's not enough, take a look of ASR's measurements on the two versions, based on the two AV8805 Amir measured, most of the measured metrics such as SINAD, were almost the same. In his conclusions, Amir commented:
Performance here is not awful but clearly could be a lot better as sister group Denon has shown. $5,000 is a ton of money for an AV product so performance needs to be much more optimized than it is. Anyway, good news is that switch to ESS DAC from AKM has not resulted in any harm. Overall performance remains quite similar.
Note in that case, the ESS chip was compared against the AK4490 not the AK4458 that is a notch below.
Also, good to know about the Denon using the ES9017. Looks like (from a different thread), you may be yourself wanting to purchase the 6800H. Any thoughts on the 6800H vs the Integra DRX 8.4?
I have the Anthem already, otherwise yes I might have chosen the Denon, because I prefer Audyssey/Dirac Live, though just slightly. Between the Denon and Integra, that could be tough, but I probably would go with Denon because of my previous experience with D+M AVRs/AVPs. The DRX would have stronger power amp section, but I use ext. amps.
