I’m not sure if it’s my ear but when I listened to tidal master 16/44 vs amazon UHD using beta firmware 8247, I find tidal master sounds more cohesive than same song using greater sampling rate. UHD sound muffled.
UHD in what resolution?I’m not sure if it’s my ear but when I listened to tidal master 16/44 vs amazon UHD using beta firmware 8247, I find tidal master sounds more cohesive than same song using greater sampling rate. UHD sound muffled.
5/31 firmware? Was it already been released?They’ve also updated their release notes page with a link to this FAQ:
What type of TIDAL Master supported on WiiM Mini?
Modified on: Tue, Jun 7, 2022 at 7:51 PM
The TIDAL HiFi subscription tier can support up to 44.1k/16 lossless music, the TIDAL HiFi + tier supports Hi-Res master content (in the TIDAL App, there is golden master tag beside song name) in the following formats:
Our App and device firmware will automatically choose the Hi-Res content to play for songs with master quality.
- Hi-Res, 44.1kHz or up, 24-bit lossless FLAC (it's supported as 5/31/22 firmware release)
- MQA, FLAC + MQA (it hasn't been supported yet)
- Dolby Atmos, Dolby master (it hasn't been supported yet)
TIDAL Master support on WiiM Mini
The TIDAL HiFi subscription tier can support up to 44.1kHz/16-bit lossless music, the TIDAL HiFi + tier supports Hi-Res master content (in the TIDAL App, there is golden master tag beside the song name) in the following formats: Hi-Res, 44.1kHz...faq-mini.wiimhome.com
96khzUHD in what resolution?
Is this on iOS?New WiiM Home app just dropped. Global search looks good.
Yeah, iOS. I’d guess the Android version won’t be far behindIs this on iOS?
On my Android Phone there seems to be no new version availible.
I guess they mean …4295/31 firmware? Was it already been released?
Global search is by far my favorite feature. I’m using this over the native apps.
I do notice that it doesn’t search UPNP servers, nor My Music in Amazon Music - I tried searching for a playlist and it didn’t show, although it does if I use the search under Browse/ Amazon Music. Ticket(s) raised with WiiMGlobal search is by far my favorite feature. I’m using this over the native apps.
Ease up, man!I do notice that it doesn’t search UPNP servers, nor My Music in Amazon Music - I tried searching for a playlist and it didn’t show, although it does if I use the search under Browse/ Amazon Music. Ticket(s) raised with WiiM
If wiim apps will incorporate amazon UHD and tidal master, I will not be using native apps.I do notice that it doesn’t search UPNP servers, nor My Music in Amazon Music - I tried searching for a playlist and it didn’t show, although it does if I use the search under Browse/ Amazon Music. Ticket(s) raised with WiiM
Is it not there yet?Correct, anticipating 192/24 for Tidal Connect soon. Hopefully!
What linear power supply are you using?I think wiim mission is to put as much as features as possible. If that happen, all others high price streamer will become irrelevant. Using wiim on linear power supply takes sound quality further over wall wart that came with it. Treble was clean and sparkling.
Topping p50What linear power supply are you using?
JM
