They will know your MAC when you send a feedback from the app even if you don't provide it.Email Wiim or use the feedback route in their app asking to be put on the beta whitelist, quoting the MAC address of your Wiim mini
Yes, see this and other earlier commentsNew beta firmware today, gapless?? Maybe
Sounds good to me.Pink Floyd must be hard to do gapless. Transitions on The Wall not great either,. What's up, any one else hear this?
The quality is dictated by what the target device I.e. the WiiM, supports. So, for example, if I ask “Alexa, play Mr Blue Sky by ELO on Puck”, it plays at 24/192 on my WiiM Mini.Once they've got the Amazon casting gapless UHD from the Amazon and the WiiM App and it's on general release don't know if anyone can answer this
I've set an Echo Dot to use the WiiM as it's speaker for anything music related, I'm guessing if I don't have the either of the Apps open but just say "Alex play ... song name / artist" ... does anyone know what will define the quality it's played at i.e. the WiiM App, Amazon App or as the command's coming from the Dot will it be restricted to the Dot's 16/44 rather than UHD.
A caveat with that though - it doesn’t support gapless AMHD playback, guess we’ll have to wait a couple of months for that…The quality is dictated by what the target device I.e. the WiiM, supports. So, for example, if I ask “Alexa, play Mr Blue Sky by ELO on Puck”, it plays at 24/192 on my WiiM Mini.
Edit: To more directly answer your query, that also works where you have the WiiM defined as preferred speaker in an Alexa smart home device group along with an Echo. Just tested that to be double sure![]()
Sorry, it’s probably because I’m on the beta that it supports that at the moment, but as the general release of AMHD casting is under two weeks away, you won’t have long to wait... Sorry again for the confusionIt becomes even more interesting if that's the case, I'm currently not on the Beta release so if I'm using the Amazon App to cast a playlist (called "Good") it won't be done as UHD (at the moment) but if I say Alexa play playlist "Good" and the WiiM's the speaker it will play it as UHD .... if I've understood that correctly?
Are you able to get gapless and replaygain working for streaming local files from the Wiim to PiCorePlayer?^^^ I'll take LMS with the Material Skin over those for playing local files to the WiiM Mini.
Use the feedback section the the Wiim app, or email WiiM support with your MAC address, to be asked to be added to the whitelist to get access to the beta firmware.How do you get on the beta? Does it have he 10 band EQ?
Thanks
WiiM is a player just like pCP. But if you've meant gapless streaming from LMS to WiiM it's only possible with squeeze2upnp in "flow" mode at the moment.Are you able to get gapless and replaygain working for streaming local files from the Wiim to PiCorePlayer?
...off to check under the couch cushions for spare change...Pro version
The review says “ In late May, bit-perfect Airplay 2 arrived at CD quality”. My understanding is Airplay 2 compresses streams to the Wim Mini and only works at lossless quality if streaming to an Airport Express ( original) device.Interesting review here but I think it underplays Amazon Music HD support, particularly its casting from the amazon music app, with some interesting footnotes about the Pro version
WiiM Mini music streamer review: Audiophile quality for just $99
Connect this tiny puck to your favorite amp or powered speakers and stream Hi-Res music anywhere in your home for a song.www.techhive.com
