Yorkshire Mouth
Any word on your measurements? Maybe just a word, good, Bad, average?
It will probably influence my decision if I will use/keep the WiiM amp.
Is that right @VintageFlanker , are you getting one in to measure?
I received one about 4 weeks back.Is that right @VintageFlanker , are you getting one in to measure?
Won't tell until my test is properly finished and repeated. Truth is, I have several products at the same time (and in fact, at least 5 reviews that just need my writing to be posted), and try to prioritise...Any word on your measurements? Maybe just a word, good, Bad, average?
You could make your decision based on this already :It will probably influence my decision if I will use/keep the WiiM amp
I’m gonna pass till WiiM amp version 2Update. Amp has a sort of humming noise. Not through the speakers. And it’s always warm even when in standby. Will reach out to WiiM and update here how it progresses.
Hi, something like this?Update. Amp has a sort of humming noise. Not through the speakers. And it’s always warm even when in standby. Will reach out to WiiM and update here how it progresses.
That type of noise is unacceptable in any amp. Glad I didn’t buy. Gotta say that is a weird noise for an amp .Hi, something like this?
You should check your wall socket grounding first. Test it with multi meter whether it’s nicely grounded.That type of noise is unacceptable in any amp. Glad I didn’t buy. Gotta say that is a weird noise for an amp .
Does it use a grounded plug and what socket and plug type are you guys using? Would be interesting to see if the issue is limited to thatYou should check your wall socket grounding first. Test it with multi meter whether it’s nicely grounded.
Ahh well darn, that is very unfortunate... I will have to wait and see how this evolves. Humming noise and hiss and whine and whatnot give me headaches way too easily :-(Update. Amp has a sort of humming noise. Not through the speakers. And it’s always warm even when in standby. Will reach out to WiiM and update here how it progresses.
Did you try to insert the power cable the other way around into the wall socket? Does it change anything?See this is what confuses me. The device uses a 2-pole, ungrounded connection and I don’t see a separate grounding port on it. Check the linked manual on page 10.
Sorry for the misunderstanding, I don’t have mine, yet. Still waiting.Did you try to insert the power cable the other way around into the wall socket? Does it change anything?
Guys, it’s £300!
Just buy it on features alone. Nothing else comes close in a single box for the money. The rest is a bonus.
There's no reason to think that my results would be significantly different than measurements from @onlyoneme. Even if my presentation, pics & editing style differ quite a bit.My WiiM Amp tests
Well, not finished. Yet. But let's start with some facts. The Amp seems to be a class D BTL H-bridge amp with a single power rail (find someone smarter than me for an explanation), and with an advanced temperature monitoring through some sensors to deliver "optimal performance and safety" which...forum.wiimhome.com
