VMV D1se2 Stereo DAC Review
Rate this DAC:
    Votes: 13 6.1%
    Votes: 11 5.2%
    Votes: 62 29.1%
    Votes: 127 59.6%
That would likely be a lot more work for little benefit. I’m guessing here, but the AP analyzer doesn’t know the volume position. So you’d have to enter everything into a spreadsheet. But the analyzer can tell you to steadily increase the volume while keeping track of the time. Any red flags will still be apparent.
That's correct. As noted on the graph, the volume control is dB accurate. And it is a rotary control so no exact position for anything.
How hard could it really be for SMSL (Topping, etc.) to realize that people who lurk at ASR also have a strong desire to extract quality-audio from HDMI/eARC? :mad:
You blew-in from the east, and you gave us (ASR lurkers, et al) some great competition for price-to-performance audio hardware.;)
Isn't time for you to step-up your (design) game again? HDMI/eARC needs you, as do I.:facepalm:
It is an entirely different world to implement HDMI. It is high-speed video interface and requires fair bit of software/testing to drive/test. Companies that build AV products can borrow such engineering but not stand-alone companies. Of course if they put their mind to it, they can.
I didn't understand, so I didn't reply.
help me.
The initial question was about increasing the dynamic range and feeding an amp output stage…
Quote: “To feed poweramps without a gain stage, direct to the output stage, also requires the said 15V to 20V to have a low output impedance, to be able to drive that section.”
I was merely pointing that what you described looked a lot like using the headphones output of a DAC+HPA combo…
The XMOS XU-316 used on the D1se2 has 16x 32 bits MCU cores. If the MQA thing is handled by the ESS9039, why do they need all that CPU power with no DSP? Only to manage the display and menus?
Simple search on aliexpress will yield a variety of HDMI/ARC audio extractors, under $100USD.
Link
8K 60Hz HDR10+ UHD HDMI Matrix 4x2 Dolby Version HLG CEC ARC 7680x4320P HDMI Splitter Switch 4 In 2 4K120Hz VRR Support PS5 XBOX
US $82.99
It hasn't been rocket science, since LCD panels w/HDMI.
I don't want them re-invent the wheel, just make it proper audio.
It does not need to be any bigger than a credit-card size daughter-card, as is done with USB/BT add-on cards.
This SMSL D1se2 would then serve a real purpose!:)
This is what you get with 24bit LDAC (from Amir's link and test).
But as Amir correctly points out:
So transparent?? I don't think so! LDAC is good, but subjectively (compared to bit-perfect) it sounds a little washed out and compressed.
It is not the hardware, I believe.
It is the CODEC itself. and first half of that is in the transmitter.
Totally OT but listening to LDAC from my phone via UAPP>Qudelix 5K is indistinguishable from wired.
Aah, got you, thanx.
But I wasn't saying that!
The mentioned DAC, has 15V at XLR output, not the HPA. and it has very low output impedance at XLR. it can practically drive sensitive speakers!
The bit about it being Amir's favourite DAC was the joke.
Because it costs as much as a DAC, amplifier and a decent pair of speakers combined !
I didn't say it cost a lot. I said that it involves high-speed video circuits which is a different design skill than low frequency audio. It also presents a challenge as far as performance as HDMI audio has a lot of jitter and high-speed/noisy circuits. All of this needs to be dealt with to get a clean audio input into the DAC.
The remote controller reminds me of Schiit Bifrost 2 remote. Wonder if it has the magnetic back as well.
Look at that CNC'ed aluminum remote, truly glorious! At this price I would imagine buyers wanting a large and hefty CNC'ed chassis as well, so maybe throw in some extra metal next time.
My original DX7 has a CNC Aluminum remote... the later models come with some plastic crap. I haven't unboxed any of the plastic remotes lol I just keep the metal one on my desk. Works with all Topping devices...
Maybe they're testing the waters of the "audiophile" swamp market :cool:
I feel like this is really what they are doing with these new products because they make no sense otherwise.
Wouldn't it be nice if TVs just had a usb out for such things.. I use usb out of my ps5 and it works fine.
Or even better.. replace hdmi with thunderbolt on consumer electronics.
Volume and source selection. And power on/off.
So you guy have one remote to control the Source i assume? But you don't control the source volume?
And another remote to to control the volume?!
Why is it not automatically using the source that is active and if there is no source goes to standby. Like me PC monitor.
And whats with the Amp, You have a third remote for this?
I do. Is that so strange? For instance when the source is a CD player it makes sense to have a dedicated remote for its many functions.
Indeed I don’t. Note that many sources don’t have volume control. Such as CD players.
Yes. When your source doesn’t have volume control, having it in your volume controlled DAC seems a great solution and a common scenario.
Don’t know. I personally hate triggered power switching. Others love it.
I don’t. Not all amps have volume control. For instance power amps or the amps in many active speakers.
So you are using a software (digital) volume control straight into a power amp. I think that's a bad decision as well.
Software glitch = 100% volume.
CD players? Just rip the CD. Play it through a streamer with PEQ etc
