SMSL DO200 Pro DAC Review
Rate this DAC:
    Votes: 6 3.4%
    Votes: 12 6.7%
    Votes: 59 33.1%
    Votes: 101 56.7%
Bamboozled:
So the spec sheet is wrong? What exactly is noise level for a 0 dBFS signal? It seems like 76 dB but this is with 90 kHz bandwidth. Amir measures 85 dB SNR at 90 kHz for the DO200 Pro. How is 112 dB SINAD possible with one and 122 dB SINAD possible with 12?
Not exactly, it just doesn't mention that the measured values use noise modulation.
Roughly -120dBFS(Z) (20-20K BW) IIRC.
12 chips in parallel will reduce noise by ~9dB. THD will cancel out slightly as well.
Do you mean noise shaping in the DAC?
How do you get 9 dB for 12 chips? I get sqrt(12) so 10.8 dB for noise. Is distortion different for different DAC channels? Otherwise it adds linearly like the fundamental.
No. As you can see in the post I linked, the cs43131 will modulate its noise floor with the output signal amplitude, similar to ESS DACs with DRE.
Ideal summing gives +3dB SNR per doubling, so indeed 10.8dB.
I just used a more conservative estimate of 2.5dB per, since summing rarely works out that cleanly in practice.
Harmonic phase differs between DACs, so can cancel out with enough sources.
I see.
They could provide detailed spredsheet if they want. But it would reduce our screen time with SMSL logo visible.
This DAC may be transparent but it can't compete with the sound signature of a my $10,000 Premium tube DAC.
Omg, another one.... brought you by SMSL.
Why the obsession with SINAD at 1kHz and not a broader range, everybody knows chinese have created products to master popular benchmarks...
Did you even read the review?
50Hz:
SMSL DO200 PRO HiFi MQA MQA-CD DAC Stereo Balanced 50 Hz 600 ohm Audio Measurement.png
60Hz + 7kHz:
SMSL DO200 PRO HiFi MQA MQA-CD DAC Stereo Balanced XLR Audio IMD distortion Measurement.png
20Hz to 20kHz Multitone:
SMSL DO200 PRO HiFi MQA MQA-CD DAC Stereo Balanced XLR Audio Multitone Measurement.png
20Hz to 20kHz Sweep, at 45 and 90kHz Bandwidth:
SMSL DO200 PRO HiFi MQA MQA-CD DAC Stereo Balanced XLR Audio THD vs Frequency Measurement.png
What more do you want?
That's just sounds insane to me! I wonder what's the benefit for that from a business perspective. I guess, more choice to choose which aesthetic you like? Because from a technical pov, they all seem to work perfectly fine. And features are mostly the same too.
possibly because they know so many* 'audiophiles' have a difficult time restraining themselves from wanting to buy the latest/newest model - despite knowing there's rarely any audible differences, just hoping to hear a difference in their systems to recreate the awe of discovery we've all had years ago with new gear?
Often it doesn't matter that you know intellectually that there is no audible difference, - you have to wonder to yourself: "Why would they use 12 DACs if there wasn't an advantage? Something to be experienced?" and that curiosity will eventually erode your restraint. So then, you sell your 'old' Mk III, to buy the 'new' Mk IV and be happy, if only until the rumors of the improvements in the Mk V start floating around....
(*not all, and least of all, maybe, ASR members - so please don't be offended! I confess, I'm intensely curious to experience the SMSL D300, because of the reviews of the ROHM BD34301EKV.... but I am pretty confident I couldn't appreciate a difference)
I'm so confused. Why they put 12 DAC chips into this device, if they can achieve the same or better SOTA performance w/ only 1 ESS/Akm chip? Just trying to understand why 12 chips are needed to put into it. Do they achieve same performance 1 ess/akm DAC chip provides? Better sound? Cheaper? Price? "Sound signature?"
I'm so confused. Why they put 12 DAC chips into this device, if they can achieve the same or better SOTA performance w/ only 1 ESS/Akm chip? Just trying to understand why 12 chip is needed to achieve same performance 1 ess/akm DAC chip provides? Better sound?
Just to differentiate their product in an insanely oversaturated market. There's no other purpose.
It’s a different design approach: put several good & inexpensive DAC chips in parallel as a way to achieve the same performances as a single, SOTA but expensive, DAC chip.
It certainly delivers on the performances side, but I don’t think it’s necessarily better (yet?).
As @staticV3 said: just “different”…
Reactions: ttt
Because the marketing department asked for it.
There is a large group of people who already have a perfectly fine fully transparent DAC and still buy a new one within a year just because the new one has 122 dB SINAD and their old one "only" has 120 dB SINAD. Plus, the consensus that newer automatically means better... some people are just sensitive to that.
