Had the Ampzilla partnered with the Thaedra mid seventies, lovely amps. Sold when I moved to Africa.
I used the Thoebe (sp?) Pre Amp with the Ampzilla.
I think the basis of any disagreement is what is state of the art?
I am an engineer and I learned early on that making something better than it needs to be is stupid, and usually expensive.
That said one has to then decide what is good enough, ie to what standard is it pointless to exceed...
Longevity in a component is infinitely more important to me than any improvement in a parameter that is already audibly transparent.
So is being nicely made and attractive.
Gee, I have one of the original Ampzilla kits up in the attic. Used it for several years. Now it's in need of repair.Just curious did you ever run across a Great American Sound, GAS Ampzilla, first Audiophile Amp I owned in 1976.
I've replaced many many capacitors and FETs in switching power supplies in large class AB car amps and as the products matured the power supply microprocessors improved and the protection circuitry engaged before too much damage occurred. I've chatted @March Audio about the protection circuitry in his class D amplifiers and it is apparently comprehensive and fast. If the capacitor(s) failed in a class D with a proper microprocessor protection circuitry then I think that should be the end of the failure(s) but don't quote me on that because stuff happens.My understanding is that the caps are under a very heavy load both in the switching PS and in the amp and it doesn't look like they are using particularly high quality caps. Since the caps are through hole they should not be hard to replace but if the caps fail do they take out other components?
and to add... The class AB car amps run veryyyy hot and go through capacitors often but the class D amps run cooler and so there is going to be a trade-off. Cooler running class D with square waves being filtered or hot, baked and blown in a hot running class AB car amp. Only time will tell if the class D amplifiers last decades.Since the caps are through hole they should not be hard to replace but if the caps fail do they take out other components?
I have a Krell KAV250a/3.
I'm using a 1991 pioneer class D amp right now. Apart from beefed up power caps it's on all the stock elna caps and is fine.and to add... The class AB car amps run veryyyy hot and go through capacitors often but the class D amps run cooler and so there is going to be a trade-off. Cooler running class D with square waves being filtered or hot, baked and blown in a hot running class AB car amp. Only time will tell if the class D amplifiers last decades.
hi ....At more than 500 euros per watt, it would be preferable that it does not present any defects. (MSRP: $32.000 USD)Questo è il mio amplificatore dal 2002, Metaxas Icarus, che ne pensi?
Roberto
My concern is that John has started this thread under a premise that he actually had no intention of the thread really being about. So we end up with a constant shifting of the goal posts: "This is great vintage amp" - "Yes, but it does not challenge or approach current state of the art" - "Well, current state of the art is overkill anyway so it doesn't matter."
My vote for iconic solid state amp would be the Crown DC300. Not saying it didn't have massive flaws though,
I suppose considering it through the lens of the times, it might be considered "perfect". But it sounded bad to my ears like many early solid state designs. Also, I haven't seen a DC300 which has physically and electrically aged gracefully, but then again I've never seen a solid state amp that old which has. On the tube side, I have seen (and own) unaltered examples of amps from the early 1960s, one with its original tubes which still meet spec.What were its massive flaws? (Considering it is a 50 year old design and taking that into account)
I started this thread so as to not derail one of @amirm 's review threads. I figured otherwise, the discussion would go down a rabbithole and result in another quality review thread getting trashed.
As for shifting the goal posts, the first post discusses where the goal posts should be, and asks for input. It seems there is just as much interest in integrated as power amplifiers, and, considering how much more time, effort and expense went into the development of the then SOTA integrated amplifiers (especially for the Japanese home market where integrateds ruled), I tend to agree.
But, getting a fully equipped integrated amplifier to challenge a modern simple power amplifier is not really a fair comparison, as half the amplifier simply isn't there. All the low level preamplification is conveniently scratched from the equation. A benchmark AHB-2 for instance achieves its fabulous figures by being a low gain amplifier with nothing else to worry about. There is no moving coil preamplifier, filters, tone controls or any facilities one requires in a fully fledged HiFi system. We have integrated amplifiers with 200uV MC sensitivities from such inputs and output stages that deliver >200W, so getting them dead quiet and performant is a significantly greater challenge isn't it?
I guess it is contenders I/we/others have had hands on experience with, either on the bench, testing, or owning for decades where the important parameters are excellent or near modern SOTA offerings. That is what the thread is about.
I'll pull out a few pieces today, take some pics and put them up for discussion. Then we'll see what testing will uncover.
Yes.
I have four Sony TAE-77es/esD preamplifiers here and they all test identically and they are all 100% original, made in 1990. I have three TAN77es (1989/90) power amplifiers here, all original, all beyond my test gear's resolution at high powers (<.002% for 30V and up).
I don't about that Sony TA-N77ES. It gets a bad review here. My suggestion of the Luxman R117 receiver out-powers itOh John sometimes you really need to put a face to the name, and what a face! And it weights 55 pounds!
How did you ended up having four of them??
