No they shouldn't I'm afraid because of the frailties of human perception. Your perceptions are biased by many factors. It's not a figment of your imagination, it's just the effect of simple human psychology. You were already suspicious of smps, you change it out for a linear psu and hey presto problem has gone away. It's simple expectation bias at play.Sorry, but how am I to agree to that? By this you are implying that neither the unpleasantness I heard before, nor my satisfaction should be taken as measures. Instead it would be wise for me to accept your judgement from a distance that my experience is a figment of my imagination. That's a tough call.
Now do the same experiment with a friend swapping the psu without you knowing or being able to see which was being used. I guarantee you will not be able to identify which was which with any level of accuracy.
Second issue here is that even if you are correct in this particular instance you have extrapolated this to mean that all smps in audio is bad. This is not the case.
My "judgement from a distance" is based on measuring power supplies under controlled conditions and seeing what effect they have.
