- Joined
- Jun 5, 2020
- Messages
- 4,840
- Likes
- 3,767
Thinking more about this, we would probably need to run all fully-decoded channels through a PC via the AVR's RCA preouts, then send the processed channels to amps. You could leave the PC volume at max and still use the AVR preamps and remote. Right? Then the question is, how to get 10+ RCA channels into and out of a PC?Just ideas in general about how to implement it, like possibly running everything through a PC but not using it as the source, for example.
AVR (room correction OFF) -> RCA - > PC -> RCA - > Amps
The main limitation is that the AVR can not also be used as the amplification because it (usually, these days) does not have multi-channel analog inputs. And, even if it did, how would you set the AVR to use those inputs, and also the input of your Blu-ray player or other source? You can't. So now we're talking about purchasing 10+ channels of amplification just to make this work.
One other potential problem I see is regarding multi-sub integration. Denon AVRs can adjust the delay of two subs independently, so no additional hardware is needed for time alignment. However, you will have two sub outputs going to the PC. I am unsure how you would handle that, so I think you would just use one channel and wait until after the PC does the EQ to split the sub outputs with a MiniDSP. It begs the question though: how is multi-sub normally handled with "SOTA" PC-based room correction, if not for a MiniDSP 2x4?
And finally, we would be performing room correction after bass management. @markus , remind me, should RC be done before or after bass management? Intuitively I would think before but I could be wrong.
