- Joined
- Jun 5, 2020
- Messages
- 4,815
- Likes
- 3,752
There's lots of sub-bass and the outside world is mutedI think "it's just your ears" as you postulated re the FH3 sounding neutral or slightly bright - as in the Harman IEM Curve may not represent neutrality for you, maybe due to HRTF differences you have that might be quite unique which could mean you require quite a different target curve. Either that or maybe you're not getting a good seal with the FH3 and thereby that makes them brighter?
Could be, but it's when I listen longer that I want to take -1 dB from the treble, not the opposite. I have the same experience with speakers. @GaryH could be right that it's the 800 - 1500 Hz area that is the issue for me, but it's impossible to not notice the difference in the treble on the graphs.Or maybe instead it's as simple as you've just burned your brain into how the FH3 sounds - if you listen to it enough then it will start to sound normal in tonality.....and it'll only be when you change headphones or listen to some flat studio monitors that you'll realise that the FH3 was quite dull.
Our hearing sensitivity peaks right in that range:
It's possible that mine drops deeper than this. Just speculating.
