- Joined
- Jun 5, 2020
- Messages
- 4,808
- Likes
- 3,749
Having said that, it is notable that the unit reviewed here (sent by Crinacle, but I'm not sure if the manufacturer knew) seems to be somewhat of an 'edge-case', with the broadband excess in the upper-mids / treble extending all the way from around 800 Hz to 6 kHz:
Well that is a problem.This could well be down to difference in measurement rig rather than unit variance (or a bit of both), but in the former case as the set-up on here uses anthropomorphic pinnae whereas Crinacle uses a pinna-less coupler for IEMs, this means his measurements could be less representative of what a human ear would likely hear, and the measurements here could be a better approximation of this, which includes that broadband 2 dB excess deviating from the Harman target between 800 Hz and 6 kHz.
Which type of measuring device is the Harman target supposed to match? Only one can be correct.
