Topping PA5 Review (Amplifier)
antcollinet
UK/Cheshire
sarumbear
This thread now has more than HALF A MILLION views! This is a stupendous number!
Well done and thank you, @amirm for starting ASR and for all of us for doing our best to nurture it. But also bravo to Topping to tap into this fantastic place. There is no way otherwise they could have achieved so many eyes on their products.
JohnnyNG
This thread now has 500+ MILLION views! This is a stupendous number!
Pretty sure that's 500,000+. :) Still, I don't recall an amp so thoroughly examined. Certainly enjoying mine every evening. I'm tempted to add "can't wait for the bigger one", but I really feel I have all the power I need already.
Nonick
Had zero noise with PA5 on JBL stage 180 tweeters. Dead silent. No thumb noise while switching on and zero noise from power block.
Compared to SMSL AO200, PA5 is a silent beast.
sarumbear
Ha! I started with half a million in mind and then wrote the wrong figure. Thank you for pointing that out. I've corrected my post.
simplywyn
After ~2 months my amplifier has broken.
It constantly sends hissing sounds and cracks to the left channel regardless of being connected to any input and amplifier power level.
Anyone experienced something like that?
Damn, seems like this amp has a lot of problems - the seller keeps asking me and I inquired this amp seems to be getting lots of returns.
asoka
Hey! How do you tell when the 125w in 4 ohm is passed? :) What position should the volume knob to be approx?
It is ok to use it with unbalanced trs? I still waiting for the cables...seems to work correctly.
P.S It is scary damn small :)
antcollinet
UK/Cheshire
No way to tell, because it depends on the input voltage and the knob position - not just the knob. It will be very very loud. The music will start to distort. Once the music is audibly distorting, you really don't want to leave it there as it can damage your speakers.
asoka
As a sound review compared with smsl da9 ...the pa5 sound ok...not striking me as a much better amp...but seems to have a little more refined highs and a better stereophony ...but on smsl I have tone controls and sda(loudness), sub out, wireless and screen. Pa5 it is perhaps better sounding but smsl much more convenience and possibility of sound controls. I have the rme adi 2 dac that has controls...other way I would prefer da9.
asoka
It is ok this configuration?
Eldus
Would it be wise to feed a PA5 with my JDS Atom as a preamp in High Gain to get the 2.6 volts over RCA with TS adapter plugs?
antcollinet
UK/Cheshire
I don't think wisdom comes into it - but it should work. I assume you are intending to use the headphone output for this - or does the gain affect the RCA output also.
daniboun
France (Lyon)
I made my own LLC PSU for the PA5, The Connex SMPS300R (single rail) has an excellent ripple (JLESTER measured it VS a Meanwell, and it performs even better). I am also using a special Audio Filter for the AC inputs and good quality cooper cables.
This is a 36V / 8.3A (stock, can be ajusted @ +-5%) 300W LLC SMPS PSU.
Some pictures :
antcollinet
UK/Cheshire
Nice build - any percieved benefit over the stock brick? I'd be surprised if there is given the impressive measurements in the review.
abdo123
Brussels, Belgium
You need an osciloscope.
daniboun
France (Lyon)
Will keep you informed here, still testing )
Here is a little table that might be useful)
Meanwell LRS-350-36 vs SMPS300RS
the Meanwell has a higher switching noise (65kHz) (192mV-pp).
Connex :
Meanwell :
