Topping PA5 Review (Amplifier)
I had to return my PA5 due to crackling noise from one channel after leaving it on for an hour - whenever i leave it on, it starts to crackle. Anyone else have this problem?
For me I'm having a noise problem, as if it is a crackling noise issue. Returning this amp.
I get a hiss even if the inputs a disconnected
I don't know if it will matter but I wonder if you get it with inputs shorted. I only get slight hiss with my ear to the tweeter on 87dB speakers with Outlaw M2200, and the noise of the PA5 is 20 dB lower than the Outlaw.
Maybe I misunderstand. Does the hiss go away after 10 seconds or does it persist?
I can't imagine this amp should hiss at all with 86dB speakers, even with your ear right on the tweeter. Do you get hiss if you short the inputs?
That "hiss" is imperceptible. Seriously, it's totally inaudible. I thought this amp was 100% silent the first time I put my ear up close to one of my speakers. I've never heard it until until my ear was up against the tweeter and I flipped the power to see if I could hear something. The interruption made me notice the "hiss" sound. I was just performing a test for a fellow forum member. I've literally never heard it before, and I can't hear it now unless I put my ear so it is physically touching the tweeter grill, and then I can barely hear it. It's magnified by the phone microphone, which is just mm's from the tweeter.
But yeah, it's not DEAD silent. ¯\_(ツ)_/¯
This should not happen. I sit 1M from my speakers powered by my PA5 for 8+ hours a day working from home. It's either Music, a zoom meeting, or silence. The amp is always on, and I've never heard a single odd artifact. It honestly sounds flawless to me, and I couldn't be happier. If yours is legit "crackling" then you have a problem.
I would agree that crackling or a thump are indications of something wrong. I have no sound in the tweeter with the input connected and amp on with no music playing. Nothing. It is dead silent.
I get no sound when turning the amp switch off is no amplified source is going to it at the time (my PA5 is fed by my L30). I get a very slight thump in both speakers if the power of the amp is turned off (using the switch) while receiving an amplified source (even if nothing is playing). I get a slightly louder thump if power is cut externally to the amp while an amplified source is connected.
I use my PA5 just for my tweeters in an active XO so amps are all on a triggered power strip. If I kill power to the system I get some scratchy grunge coming through the tweeters but nothing if I use the switch on the front of the PA5. I just turn off the PA5 first before powering everything else down and then flip the switch back up so it's ready to go next time. Not ideal, but not a deal breaker for me as the amp stack is close at hand.
The symptoms are common to all PA5s. The only disappointing point of PA5.
I tested PA5 shortly after launch and posted this issue on the forums.
I'm feeding it from a balanced miniDSP Flex. Behavior is identical if I unplug the input cables from the PA5, or if I switch the PA5 to use the other input that is not in use.
If the noise appears even when nothing is connected to the input of PA5, it is a malfunction of PA5.
I had the exact same problem. Returned to APOS, replacement unit is on the way. Hopefully the replacement won't have the same issue.
PecanPi cranked to max volume, PA5 cranked to max volume, dead silent ear against the tweeter. I can hear a very very faint pop when I turn PA5 off, it's really not bothersome at all, barely notice it. When the PecanPi's volume is dialed down to where I normally keep it, no click sound at all when I turn off PA5. (I was getting more noise when running Unbalanced with E30 DAC)
The crackling sound is regardless of volume.
You have to short the inputs to eliminate interference pickup. They are designed to be driven from low impedance. Open circuit isn't.
After ~2 months my amplifier has broken.
It constantly sends hissing sounds and cracks to the left channel regardless of being connected to any input and amplifier power level.
Anyone experienced something like that?
This thread now has more than HALF A MILLION views! This is a stupendous number!
Well done and thank you, @amirm for starting ASR and for all of us for doing our best to nurture it. But also bravo to Topping to tap into this fantastic place. There is no way otherwise they could have achieved so many eyes on their products.
