It is known that there is no problem in the input part of PA5 even if a balanced input signal of 26Vrms is applied.I had asked the brand directly earlier, I'm happy with the answer
I'm going to try in preamp but I'll make sure I don't push the dac too much I really don't want to damage the pa5
Does that mean I can put the d90se in the dac position with 4Vrms on the XLR output? I haven't dared to do it yet.It is known that there is no problem in the input part of PA5 even if a balanced input signal of 26Vrms is applied.
On the other hand, the output of PA5 starts clipping from about 23Vrms (4ohm), so it is necessary to adjust the volume knob of PA5 so that clipping does not occur.
There is no problem connecting the D90SE XLR output terminal of DAC mode (either 4V or 5V) and the TRS terminal of PA5.Does that mean I can put the d90se in the dac position with 4Vrms on the XLR output? I haven't dared to do it yet.
You just have to avoid putting the volume all the way up on the PA 5 if I understood correctly.
Thanks for the pictures. It is quite likely that your PSU output measures better than the stock PSU output. It is difficult though to see this translating into better measurements at the speaker, given how good the measurements are with the stock PSU. It already has a ridiculously low noise floor.Hi amigos,
Here some new pictures of the PA5 Stock brick PSU
First of all, I don't think this is neat PSU, I measured it @ 35V only with oscillations between 34 and 36V on the multimeter...
The Output caps are are branded "Vent", and tagged as being low ESR. (50V / 680uf)
The Power Management controller chip is a TEA88181T/1Y, that is a half bridge resonant converter , with PFC.
The PCB from the stock PSU inspires rather confidence but I do not have sufficient knowledge to judge...
In any case I am sure of one thing, the Connex 300RS LLC PSU is much more stable on the multimeter and I imagine it measures better without a doubt )
Some pictures so you can see from inside :
Connexion 300RS + PA5 stacked.
True - if at maximum volume a PSU with a +/- 1V instability could take you in and out of clipping. But you'd only have to worry about it until your eardrums brokeIn my opinion, where we would really notice the difference is at a high listening volume
Do you need banana plugs to connect speakers to the terminals or do they have holes in the stock to put bare wire?
Unfortunately I chose to return this pa5, after comparing with smsl da9, one amplif to a speaker another to the other speaker and instantly A-B between them. Discovered that pa5 sount thinner and more strident than smsl da9...and this is the exact opus as what I wanted. Pa5 had upper mids and highs exaggerated on top of the bass that will make it sound bass thin and more aggressive with thinner mids...more thin voices because this. Smsl it is better balanced with more full body voices and because not so aggressive high mids and highs with am more apparent bass presence.
What a pity that ASR did not measure the Sabaj A20A which pleases many people, including me)
I like too the Sabaj A20a.The Merus MA12070 chip sounds warmer than the TPA325X. This is what I reported with the Sabaj A20A that is using the same dual Merus chips.
In the category of amplifiers under 400 euros, the PA5, the Sabaj A20A and the SMSL DA9 are safe bets!
