PA5 arrived from Aoshida HiFi and I immediately tested it in combination with E50. This is an intermediate report.
1. There is no noise when turning the power on/off and switching the input.
However, if the AC plug is suddenly unplugged while the power is on, noise will be generated for a moment. The noise level isn't high, but this is a bit disappointing.
2. Noise from the speaker when there is no sound cannot be heard even if the ear is in close contact with the speaker unit.
3. In this season, the heat generated by the amplifier case is a little warmer, but in midsummer, the heat generated will be even greater and the slits in the case will be effective. It is a fever situation similar to AIYIMA A07. (In my research, I think the chip used is TPA3255)
4. The volume change of the volume changes linearly and smoothly. The volume change is the same as TP60, PA3, PA3s, etc. Probably the taper A for audio is adopted for the volume pot. I don't feel any gang error.
5. It is pointed out that PA5 has a low gain, but it is not a problem for home use in the test in combination with E50.
6. Regarding the sound quality that is most worrisome, I compared it with PA3s, AO200, A20a, and AIYIMA A07/A04, but PA5 produces a different dimension of sound from these amplifiers.
The energy of the mid-low range, the transparency of the high range, and the resolution are improved. It sounds like an upgraded version of the highly acclaimed MA12070 chip amp. The first thing I felt when I heard the sound of PA5 was the size of the sound stage. When you hear this sound, you are satisfied with the price of PA5. However, how you feel the sound varies from person to person, so please understand it for reference only.
