Topping LA90 Review (Integrated Amplifier)
Rate this amplifier:
    Votes: 35 4.4%
    Votes: 50 6.2%
    Votes: 194 24.1%
    Votes: 525 65.3%
DrSpan
This is a review and detailed measurements of the Topping LA90 integrated amplifier. It was sent to me by the company and costs US $800.
I must say, this is one interesting industrial design. Everything oozes style despite the diminutive package. This aspect continues in the operation of the unit with the sound of the relays solidly clicking indicating something good is going to happen. :) Here is the side view:
Due to more power available now, we cross the amazing 140 dB SNR threshold. What this says is that even if you play at 140 dB, the noise level will be at or below threshold of hearing! Of course there is not enough power there to do that but basically you know that noise is not part of the equation with LA90 as even 5 watt measurement hits below threshold of hearing.
We want to know the power increase though so here it is (with 8 ohm which is the minimum impedance):
Amazing. Also funny format. It looks like someone took an Spl Volume 2 and put an amp inside.
This site is amazing. If it was easier to send things ot the U.S but….customs. I would have send you the Tangent Powerampster 2 i had for a few days. Felt very well build
but i send it back cause i had no way of testing it since my speaker died one day before it arrived.
Keep up the good work Amir!
Ziofrenko
Italy, Rome
To be clear; when you talk about dB SPL you talk about dBC -right?
If you are, I agree with you. Having a system capable of high SPL and low distortion is something everyone should try. But it's not exactly the same to say you want the levels that are present on the stage. The musicians are wearing hearing protection (I hope). :)
A drummer wear ear protection (now, non in 70' or 80' or 90').
A symphony orchestra, no, it seems banal to me... The orchestra can reach 120dB, but it doesn't maintain it for 10 minutes.
And I would also like to remind you that there are tables on hearing damage based on pressure... They depend on the amount of time clearly.
glorei
I have just one question. Its a good choice (L90) for B&W 683 S2? Now i have dac Topping DX3 Pro+, but amplifier (receiver) Yamaha RX V 659. Thank you
antcollinet
UK/Cheshire
What do you expect to get from the change.
If it is sound quality there is a good chance you won't be able to hear a difference from the Yamaha in pure direct mode. The Yamaha is already very good.
Ziofrenko
Italy, Rome
As always it depends on how sensitive the speakers are, the maximum SPL you expect and the listening distance... And clearly from the environment!
nagster
This is a graph of THD ratio versus generator level. This is for checking the allowable signal level of the LA90 input section.
staticV3
Thank you for the measurements!
So basically, the LA90 has an effectively un-clippable input. Nice!
Also relevant to @babadono I believe:
Also anybody know the maximum input level before clipping the input stage?
babadono
Please educate me... how does this show that the input is unclippable? Do you mean that it is always the output section that clips before the input? The input still must have a limit though, correct? All I want to know is the maximum signal input say +20dBu or whatever it might be. On the semi pro gear that I am interfacing with these type of specs are given. Both input and output.
staticV3
Correct.
Not necessarily. A simple passive attenuator has no clipping point as-such.
With the LA90's volume control bypassed, you can input 6.9Vrms (=19dBu) in Low gain, or 2.2Vrms (=9dBu) in High gain, before the Amp's output clips.
With the volume control engaged however, even 25Vrms (=30dBu) is not enough to cause clipping, provided that you set the LA90's volume knob low enough to avoid clipping the output.
babadono
So the "volume" knob is a dual differential passive attenuator? Now I REALLY want to take one apart:)
nUUK25
Copenhagen, Denmark
I've had just one LA90 for some time (July) and realized that with two the sound might be less constrained. Two month ago I've bridged (mono) two amps, one for each speaker and it works wonders in terms of the past 'constrainment'. Definitely an audio quality ascent ! Now I'm thinking I might gain some improvement with another two LA90 in the setup as my Martin Logan Electromotion speakers are bi-amp capable. I doubt the improvement will be proportional; two to four, but even less are welcome ! The fact that one amp will be dedicated to the electrostatic section and another amp to the dynamic section in itself might reveal more clarity. If I do go for it I will report back here !
A lot of time has passed - Well, not a surprise ! 4 are better than 2 - it is worth it !! :)
SashaR
I ask for the help of experts!
How to use the Topping D90SE and Topping LA90 kit with the greatest efficiency?
1. The D90SE DAC should be used in DAC mode, WITHOUT volume control, - and the LA90 amplifier should be used in volume control mode.
2. The D90SE DAC is used as a volume control - and the LA90 amplifier is switched to the mode WITHOUT volume control.
USB cable comes to the input of the DAC, and 4-ohm speakers with a sensitivity of 88.5 dB (Vela 408) are connected to the output of the amplifier. The interblock cables are XLR.
Thank you very much!
antcollinet
UK/Cheshire
Audibly it won't matter. But operating the DAC in DAC mode, and controlling the volume on the amp will give you the best technical SNR.
Plus that method protects you from the (pretty unlikely event of the) DAC spitting its dummy and putting out full volume.
SashaR
But they have very different "structure" of distortions and reasons of them! The different superposition MUST be matter - maybe even audible (for example, Topping ask me to prefer the DAC mode of the D90SE).
This aspect - the best technical SNR - is the kind of the effect which I loock for! BUT much-much more I'm interested in the minimizing of all other artefacts (intermodulation distortion, harmonics, etc.)... Which superposition will better in this matter?!
I was told that the LA90 volume control does not work well (distorts at the low volume levels at which I use it) - and this is one of the main reasons why I started looking for a way to improve the situation - and that's why I want to replace the LA90 volume control with the GOOD DAC's volume control!
I was suggested to use a headphone amplifier with a relay volume control - but I don’t need headphones, and, besides, an additional hardware module will definitely lead to sound deterioration ("technical" as you put it. Or even audible?)
Thank you very much!!!
antcollinet
UK/Cheshire
Other than the possible low volume issue you have mentioned, it will make absolutely no difference.
I think the low volume issue you mention will be channel imbalance - possibly non linearity if at very low volumes. In this case, then yes you will be better off using the DAC volume.
If you are going to do that, I'd suggest turning the DAC up to full, setting the amp volume to the maximum you could ever want to listen to (or alternatively the maximum safe level for your speakers), and then use the DAC to turn it down from there.
SashaR
Thank you very much for your advice!
But please forgive me for the stupidity of my clarifying question:
Will switching the amplifier to “direct” mode (bypassing the volume control using a switch on the back of the amplifier) be the correct implementation of your recommendation (my speakers have more than twice the power reserve compared to the maximum power of the LA90 amplifier)?
Please tell me in which mode is it better to use D90SE? With the 5-volt version, I set the D90SE to -35 dB as the “central” point of the “volume control” - but in Amir’s measurements it is clear that the local minimum of SINAD is achieved at 2.5 Vrms (in the 5V mode)... How can you make the D90SE work in the best area of SINAD, varying the settings of the DAC - at what decibels on its screen do I get closer to the least DISTORTION and at what its mode (5V or 4V) ?
SashaR
Is there a similar graph for the TOPPING D90SE DAC (THD as function of the dB-on-the-screen) in its "PRE-amplifier" mode - and anything about its DAC mode to be able to comare with PRE mode?
nagster
First of all, my English ability is that of a 3-year-old. Please don't be offended.
I'm using Google Translate but I don't understand it well. Is this link helpful?
What is "PRED-amplifier mode"?
nUUK25
Copenhagen, Denmark
What works perfectly for me: Ad2. Go to D90SE (in preamp mode) and the setup and set from 4 v to 5 v. Keep the low gain on LA90 and no volume - only set to high gain if you need more output from speakers. Just a tip about speaker plugs. Get the bananna plugs which are male tube shape : they will have a large contact surface on the plug in the speaker. Don't get the ones (male) which push the plug to the side in the speaker plug by a spring. They are all shit with less contact surface but quite common !
