- Joined
- May 15, 2019
- Messages
- 880
- Likes
- 3,630
If you don't need as much power as the HS02 provides (true for all DACs with power supply), or its extended feature set, then you could save some money with the new Hifime USB High Speed isolator. It also uses the AD UM4166 and an additional DC/DC isolator with a bit less current (still 500 mA), but also better isolation (71 pF coupling capacity only). I know because I got one already.I need a ground loop breaker / hum reducer for my Fiio k5 Pro ESS (connected to a windows desktop PC and active monitors or headphones).
The K5 Pro (XMOS USB Receiver) is not USB powered and has an external power supply.
Is there any reason to better buy the HS02 or can go with HS01 without the additional power supply isolation and it is supposed to work fine? Is there anything the HS02 would do better in my case?
Hifime Hi-Speed USB Isolator - new 2023 version
The Hifime High-Speed USB Isolator is designed specifically for audio and supports USB Hi-speed mode that is required by many Audio devices. It will prevent ground loops, prevent interference and protect your equipment against power surges.
hifimediy.com
