MaxwellsEq
- Joined
- Aug 18, 2020
- Messages
- 3,313
- Likes
- 5,745
Almost everything you normally hear comes from the main drivers, NOT the tweeter. The only bit of voice you will hear coming from the tweeter is the leading edge of "s" and "t" sounds. But even then if you disconnect most tweeters, the voice will sound almost normal, but slightly softer t and s sounds than normal.You means vocals also will be coming out of the mid range? But i usually listen at considerably loud levels -20db
