Yes it is.
Do you mean it has 2x ES9038Q2M chips?
Yes it is.
ES9038Q2M already has balanced outputDo you mean it has 2x ES9038Q2M chips?
Ah didn't know that! because the SMSL SU-8 had 2 if I remember correctly so I thought you need 2 for "real" balanced.ES9038Q2M already has balanced output![]()
You need two for dual mono. One chip has a perfectly suitable differential output.Ah didn't know that! because the SMSL SU-8 had 2 if I remember correctly so I thought you need 2 for "real" balanced.
It makes it a cheap, darn high quality little interfaceI didn't read the entire thread, but I've often wondered why the D10 models have SPDIF outputs. Why not have inputs?
To me there's nothing to miss coz the previous version D10 and D10s didn't have coax in nor optical in
Kinda blocks the vent holes. A30Pro gets hot enough as it isView attachment 142466
matched the width based on dimensions given
Well, Topping markets the D30Pro/A30Pro stack with D30 on top which would block even more vent holes. Also, @JohnYang1997 said it wouldn't cause any issues.Kinda blocks the vent holes. A30Pro gets hot enough as it is![]()
Never said it would cause any issues.Well, Topping markets the D30Pro/A30Pro stack with D30 on top which would block even more vent holes. Also, @JohnYang1997 said it wouldn't cause any issues.
Would love to see a head-to-head between the Behringer MONITOR1 and the JBL NanoPatch+.Cheap DAC + cheap monitor controller
Behringer Monitor1 40 €
https://www.thomann.de/ie/behringer_monitor1.htm
https://jblpro.com/products/nano-patch-plus
I like the Mono button and dual XLR I/O on the Behringer.
It would be nice to see performance across the potentiometer range.
