Topping B100 Amplifier Review
Rate this amplifier:
    Votes: 31 6.4%
    Votes: 26 5.4%
    Votes: 85 17.5%
    Votes: 343 70.7%
Late response but since this is class B or AB. What’s the short-term output at 1% THD? @amirm was it measured?
50 watts is a LOT unless you have ridicilously inefficient speakers.
Relatively inefficient speakers: 83db@1M@1W > 100db@1M@50W
In my home - 86db is plenty loud for me, and I usually listen at about 2M > that means I'd have 14db of headroom or dynamic range. Todays music ranges between 7-15db of DR.
Thus, I can conclude, that in most cases - I can be certain that I will hear all I need to hear using a 50W amp without concerns of clipping.
Infact, 86 db continuous seems VERY loud to me, and I usually prefer to see the needle bounce around between 70 and 80 db for comfort, which further means that 50W will most likely be "guud 'nuff".
EDIT:
A further consideration: I would love to see the percentage of people that can hear the diffence between 115db SINAD and 85db SINAD. Which further makes me consider - that we are discussing academic things here (as relates to most people).
This doesn't work for many of my speakers, but I can see it having a place, albeit niche more than common.
Beethoven had Jecklin Floats.
He had much more bulk: several huge acoustic cornets were built for him so that he could hear a little: they were suspended above the soundboard of the grand piano which they completely covered and went up to his head and ears...
peniku8 said:
Not exactly sure who this product is aimed at.
The Internet.
Internet? I don't know this speaker... But I know of high-efficiency horn speakers whose real efficiency is around 98 dB-100 dB which will be particularly happy to be amplified by an amplifier whose signal-to-noise ratio will not make you hear no noise even though the B 100 will deliver 0.25 watts into the coils of the speakers and compression chambers... and it will be able to reproduce without any compression or distortion the instrumental attacks which are not perceived as sound level higher as they are ultra-brief but whose perfect reproduction should not be put aside.
And then, they are small, pretty, still make around fifty watts, which means that in a bare interior, they can be hung on the rear panel with their amplifier, or just placed behind them, direct radiation speaker speakers. whose efficiency is between 88 and 93 dB... that's more people than we think... These small amps which are multiplying are at the same time pretty, efficient, inexpensive and there is therefore another category potential customers who want to see what they can do and who therefore install a second small chain in an office, a bedroom, a large kitchen...
I tend to agree, but have not ever done a blind A/B comparison to confirm. The only thing that I can confirm is that when I stick my ear next to my KEF LS60 tweeters I can hear the noise (a slight hiss), but cannot hear any noise when I stick my ear next to the tweeter in my Elac speakers, which are actively driven (no passive crossover) by a Topping LA90D amplifier. The noise in my KEF LS60s is inaudible to me at 1m, however.
One possible issue I have not investigated is the combination of noise from different components in the system. E.g., if you have a DAC with 95 dB SINAD feeding an amplifier with 85 dB SINAD, does it start to become audible?
I can basically press my ear up against the coaxial driver on my LS50 Metas when hooked up to the B100 and I hear almost nothing (the absolute faintest super high-frequency ring that is inaudible more than a few inches away).
-Ed
(EDIT: From the review) "I tried to measure power at 1% THD but the protection circuit would not allow it. THD would remain incredibly low and then shut down if I increased input voltage. So 86 watts is what you get for max and peak power."
That correlates with Amir's data. Topping should revise the specifications, or revise the design to meet specifications.
I was quoting Amir there, sorry for not making that clear. I think he said that if he knew exactly where protection kicked in he suspects he could replicate Topping's results. Nevertheless, that is one zealous protection circuit! I don't know squat about amps but is this related to the high amounts of negative feedback making the amp unstable once it starts to distort?
Thanks, saw that for 4 ohm, but not 8 ohm. So I wonder what short time burst gives in 8 ohm
Good question.
Going back 4 decades, a number of class A/B amplifiers would provide short bursts of power well above their RMS performance. I recall one amplifier specified as being 75W/ch, but it only would do so in short bursts. It's continuous RMS power output was closer to 15 or 20W.
Thinking about that, I wonder if modern amplifiers, such as those from Topping, are capable of providing output well above their RMS rating in short bursts. That could help with short music transients in uncompressed music. If anyone knows, please chime in.
The issue with trying to use Pink noise for harmonic distortion is that it is just that, noise, but noise that is generated over the entire audio spectrum at a constant level. The noise masks the harmonics. For example, say you want to measure the harmonics of 1kHz. Those harmonics will be at 2kHz, 3kHz, 4kHz, etc. and, hopefully, be at least -30dB down from the 1kHz signal. But, with Pink noise, there already are signals present at those frequencies, and at the same reference level (assuming a system with a flat frequency response). Thus, you will not be able to get an accurate measurement of the distortion. The harmonics will be buried in the noise.
I understand for measuring distortion, my original post asked about measuring power output. Music clean real power instead of measuring with a 1K or 40hz tone.
It lets it clip with 8 ohm load so that is not it. I think they are being super conservative to protect the amp from damage. 4 ohm uses much more current so makes sense that protection circuit is well, more protective there. :)
Because it really wouldn't tell you anything that distortion vs freq vs power sweeps into various loads don't, but would offer less diagnostic value.
Would point out that those dB figures appear to be measured immediately adjacent to the instrument itself so would not reflect what one would hear in an audience seat however many feet away. And it would also not reflect what appears on most recordings after being mixed and processed. It's biggest point might be that the musicians playing those instruments might want to consider hearing protection. ;)
There's no point reading the numbers of a chart if you don't read the conditions,etc:
Numbers next to it also state the different special conditions if measured (at the ear,at the bell,etc).
The typical max though are all at 3 meters (that's about 10 feet I think)
EDIT:
Your understanding of your power requirements are potentially horrifically wrong. Go watch the Harbeth video about how much power you need. They ran a pair of similarly inefficient Harbeth speakers with a CH Precision amp that had fairly accurate watt meters. It was not particularly loud, and the speakers were not in distress. Guys were literally going up to the speakers and putting their ears near them and you could still hear them talking in the room. They were peaking well over 600 watts. Poor Alan Shaw was standing there with a look of disbelief on his face. Granted, that a track that drew a lot of power. On some boring chamber music they barely hit 50.
Most Class D amps and most amps with switching supplies are not. There's not help there. CEA spec Peak power ratings are also unlikely to help all that much since the burst is shorter than most of the musical transient requirements. Unless you get an old NAD or something. Amps like the Topping are likely completely out of gas at their rating, which is what the review says.
Probably not. There's a calculation for that, but it typically degrades the worst component a dB or two (strictly speaking, that's just adding noise, but that's all there probably is to add). In your example, since it is 10dB better than the amp, you'll end up with maybe 84dB. Note that SNR at 5W is not necessarily the right measure here on the amp side. You would use amp SNR or SINAD at full power. If you want to know whether the noise (or THD+N) is audible, at low powers, you can tell whether there is potentially audible noise by, well, listening for the obvious. Distortion will be in the noise. At higher powers, the noise will get masked, distortion will emerge. This amp is somewhere better than -120dB at full power (the analyzer is bottomed out). It reaches levels which are well below the guaranteed audibility threshold for noise and distortion even with 100dB sensitivity speakers (1kHz). It's well over 30dB better than necessary on 85dB speakers.
On 85dB speakers, a 5W SINAD of -80 is well better than any normal person will ever hear in any normal room, at listening position. Any distortion and noise at 1kHz is inaudible, by definition. With music playing, -65DB will be completely transparent to most people at low 5W levels since any distortion is buried in the noise. Once out of the noisefloor, IMD is going to be a much bigger problem since it may not benefit as much from masking. So, no, amp+DAC combo inaudible due to SINAD alone.
