terryforsythe
I suspect that the vast majority of people commenting that 86W/ch is not enough power have never measured the SPL of their system when listening to music, and have no idea of how much power they actually are using.
I'm in the market for an amp, actually, for my PSB Platinum M2 speakers. I finally have a space in my house for them; they've been sitting under my basement stairs for several years.Unless someone is using really inefficient speakers or playing the speakers in a really large room, they probably don't need more power.
Moreover, many people will use the B100 for bookshelf speakers. With a couple of exceptions (e.g., KEF Reference One), most bookshelf speakers will be exhibiting high levels of distortion and high compression by the time the power limit of the B100 amplifier is reached, and should not be played that loud.
Of course, the only problem with a paper assessment such as this is will one get 100 dB SPL across the full bandwidth of which the loudspeakers are capable, playing actual music, and -- if so -- for how long before thermal shut-down or other, similar sequelae?
I mean... maybe...
This being said, I fully (!) support the notion that 50 watts is a lot with loudspeakers of any reasonable level of sensitivity (and non-sadistic impedance and phase curves).
Please stop listening to audiophile fairy tales.I've heard massive amounts of feedback (often used to get these kind of low numbers in AB amplifiers) can flatten the sound or narrow the soundstage width ... but I've never heard this or tried, has anyone compared an amp with heavy feedback to a low feedback, but good measuring a/b amps?
THIS! Typically when listening to music with a vocalist, I set the volume at a level that makes sense (to me, being a vocalist myself). If it's too loud, that experience in and of itself just feels unnatural.
I do turn the volume way up on big orchestral recordings because if you're in a concert hall with a 30-piece orchestra, it's going to get LOUD.
-Ed
Well, yes, but I suspect headroom comes in handy ... I often think the debate should include the implementation of compression at the recording and mixing stage ...I suspect that the vast majority of people commenting that 86W/ch is not enough power have never measured the SPL of their system when listening to music, and have no idea of how much power they actually are using.
Well yes, in a way. Bring back dial in loudness controls for low level listening. I do find myself enjoying my V3 mono watts though ... even the small amount of them I am using!Another thing to keep in mind - it's been proven over and over again that -at lower listening levels- our hearing benefits from slight boosts in lows and highs. So super-linearity may not always be the audio nirvana we sometimes make it out to be. I also have a long history of stating that the extreme power numbers that now seem standard with Purifi and Ncore designs just make me shrug my shoulders, it's a very 1980s thing to go "Duuuuude you can really FEEL this!" and be impressed by that. I want finesse at everyday listening levels. A refined 50W is plenty, especially as we can now optimally set up subs easily.
Please don't be condescending. Music is not a 40hz or a 1K tome either. So the questions comes from the ability of the amp to amplify music (made from multiple frequencies) not just a single tone. Also, Pink noise is not distortion, is just all frequencies played at the same time and same amplitude. Hence in cases used to tune and equalize (car audio).You want to measure distortion using noise? In the terrible analogies department, that's like measuring optical clarity using a lens covered in dirt.
Just to put things right,in not only about SPL.There are db's and realism to consider ...
A standard drum set ranges between 90 decibels to 130 decibels.
I would not want a drum kit in my room.
75 decibels might be an acoustic guitar played to the max ... so I could max out happily listening to an acoustic guitar maxing out at 75dbs ... but 50 db's would not be particularly realistic representing said guitar ...
A good saxophonist gets just over 95 dB out of a saxophone. I once measured it in the studio when there were a few problems with a recording.Just to put things right,in not only about SPL.
A kick drum can go to 125dB,yes,with the pedal far enough (18-20cm) from the drumhead but the important thing here is its dynamic range which can go up to a staggering 80dB.
And,acoustic guitar is not at 75dB,is more closer to 90dB.
(you don't even want to know what a sax can do)
Here's a capture of 12 minutes of sheer beauty:I suspect that the vast majority of people commenting that 86W/ch is not enough power have never measured the SPL of their system when listening to music, and have no idea of how much power they actually are using.
(close to 120,yes,a hundred-and-twenty dB at the center of the bell for extreme forte for an alto)A good saxophonist gets just over 95 dB out of a saxophone. I once measured it in the studio when there were a few problems with a recording.
The issue with trying to use Pink noise for harmonic distortion is that it is just that, noise, but noise that is generated over the entire audio spectrum at a constant level. The noise masks the harmonics. For example, say you want to measure the harmonics of 1kHz. Those harmonics will be at 2kHz, 3kHz, 4kHz, etc. and, hopefully, be at least -30dB down from the 1kHz signal. But, with Pink noise, there already are signals present at those frequencies, and at the same reference level (assuming a system with a flat frequency response). Thus, you will not be able to get an accurate measurement of the distortion. The harmonics will be buried in the noise.Please don't be condescending. Music is not a 40hz or a 1K tome either. So the questions comes from the ability of the amp to amplify music (made from multiple frequencies) not just a single tone. Also, Pink noise is not distortion, is just all frequencies played at the same time and same amplitude. Hence in cases used to tune and equalize (car audio).
REW can now use Fast Subband Adaptive Filtering for measuring THD+N using pink,white,brown noise or even music.The issue with trying to use Pink noise for harmonic distortion is that it is just that, noise, but noise that is generated over the entire audio spectrum at a constant level. The noise masks the harmonics. For example, say you want to measure the harmonics of 1kHz. Those harmonics will be at 2kHz, 3kHz, 4kHz, etc. and, hopefully, be at least -30dB down from the 1kHz signal. But, with Pink noise, there already are signals present at those frequencies, and at the same reference level (assuming a system with a flat frequency response). Thus, you will not be able to get an accurate measurement of the distortion. The harmonics will be buried in the noise.
What settings did you use to show the LA and LZ measurements?Here's a capture of 12 minutes of sheer beauty:
Can someone please state at what level I listen too?
Bedřich Smetana's - Má Vlast: Vltava :
To make it easy,average,min and max are (A) weighted,peak is (Z) weighted (as always) .
Open REW,choose the "SPL meter" tab and then choose SPL,choose weighting,fast or slow and Logger.What settings did you use to show the LA and LZ measurements?
Using the RTA in REW, I measured RMS and Peak, sampling 3 songs. This about as loud as I typically listen, measured at about 2m:
Also,as a test use a bass-heavy song and first measure it with (A) weighting and then with (C) weighting WITHOUT changing level and observe the big difference as the later captures lows too.What settings did you use to show the LA and LZ measurements?
