Poor Diana Krall. She might always be associated with audiophile nonsense.
Is this thing solid and not flexible?? That would be a real pain, along with the pain in your wallet.On topic: Is it shaped like that? Might make system integration a trifle tricky.
Only 900 bucks! It's a steal! Get a couple for the kids!You had better place your gear in the exact position from the wall socket or this perfect geometric form will be wrapped around my neck by my Wife when she sees me installing something like this! Bloody Hell. The insanity has no limits. We should all immediately try to go insane because these brainless crazies have all the money.
I am sure it's at least nominally flexible IRL (as they say), and the serpentine configuration in the (artificial) illustration is an affectation for aesthetics' sense.Is this thing solid and not flexible?? That would be a real pain, along with the pain in your wallet.
Well, and Declan (Elvis).Poor Diana Krall. She might always be associated with audiophile nonsense.
I think the black part would allow it to retract like a kitchen sink faucet.Is this thing solid and not flexible?? That would be a real pain, along with the pain in your wallet.
ImpressiveHere are the specs - for the $499 and $899 variants. Surge protection and noise reduction are identical indicating the active noise reduction and surge circuits are the same. The only difference is the weight in the $899 variant, which tells me there is more insulation. Also, both will be flexible with the more expensive version needing more help “forming“ the cable shape to the path used. Compared to insanity priced cables from certain other OEM’s these seem like a bargain. Whether they make any difference in what you “hear” is quite another matter. Having active noise cancelation and surge protection could be considered a “plus” and specs are given. Which would seem to invite someone with discretionary funds to send one in to Amir for testing (not me as I don’t use discretionary funds to buy high dollar power cables).
I admittedly still use my Pro iCAN Signature amplifier, primarily for the xBass bass boost, a feature that I haven’t been able to find elsewhere, They just released this insane iCAN Phantom which ups the ante on the Pro iCAN Signature by making all of the settings controllable by a remote, adding another watt of power, and adding an electrostatic energizer integrated into the main unit. The original Pro iCAN didn’t measure so well on here, not sure about the later iterations.Yeah, after I sold my iCan Pro amp, I kinda regretted it..... after seeing this, I don't anymore to be honest, lol.
Sacrilege! That was just the Nova, this is the Quasar! Even the name tells you it’s way bigger and better.Is this basically the same cord?
https://www.amazon.com/iFi-SilentPower-SupaNova-Power-Cable/dp/B091B6TVT8
The truly unfortunate thing is that they make quite a bit of very decent, affordable and popular DAC and DAC/amp combos, that have brought high end listening experiences to countless everyday consumers. Their desktop Zen line has a lot of fine options for less than $200, and their portables such as the Go Bar, Hip DAC 2 and xDSD Gryphon are all very decent options for those who are just looking for a well-made consumer grade product with little fuss.Here we go again, another firm that discovered that the easiest way to make money in audio is to sell cables
Very cheap to make, almost no risk of failure (how often did your cables break down) and the fools believe you when you claim it is the best sounding cable.
That and they gave 250 vac ratings for the Supa but not the Nova. Other than the appropriate connector/terminals for these respective cables, are voltage ratings even a thing for cables with this little resistance, especially for those at this gauge? I would think wire is wire if resistance measures are identical. And since when do power cables have “noise reduction” ratings? Also what does “no shielding to reduce capacitance” mean? Isn’t shielding the primary method to reduce EMI?Here are the specs - for the $499 and $899 variants. Surge protection and noise reduction are identical indicating the active noise reduction and surge circuits are the same. The only difference is the weight in the $899 variant, which tells me there is more insulation. Also, both will be flexible with the more expensive version needing more help “forming“ the cable shape to the path used. Compared to insanity priced cables from certain other OEM’s these seem like a bargain. Whether they make any difference in what you “hear” is quite another matter. Having active noise cancelation and surge protection could be considered a “plus” and specs are given. Which would seem to invite someone with discretionary funds to send one in to Amir for testing (not me as I don’t use discretionary funds to buy high dollar power cables).
I don't see how though, the choice of a suitably chunky ground conductor excepted. No matter how fancy the L and N conductors are arranged, lumped capacitance to either of them is going to be about equal, and one is always going to be phase (full mains) and the other neutral (0 V return). (And then there's still power supply filter capacitance in the attached device.) Magnetic fields from currents flowing in L and back through N would cancel as advertised, though I don't see how they'd have any effect on PE to begin with.Our Ground Zero design ensures the grounding conductor within the cable is unaffected by residual magnetism and unwanted induced voltage.
That reminds me of the "clean-up shunt" approach:iFi’s active system uses inverse noise current to cancel out the noise in the mains signal. Noise in the mains supply occurs at different frequencies, depending on the cause. Active Noise Cancellation II technology enables a power-conditioning device that is highly effective at reducing noise consistently across the entire frequency spectrum yet sufficiently compact and lightweight to position within the mains cable itself.
But these descriptions work to sell the product.The product description is good for some hilarity in general.
"Polymer casing for lasting durability for excellent conductivity" = PVC jacket?
"Finally, the SupaQuasar active power cable is finished in an impact resistant polymer casing for long-lasting durability" = ABS plastic?
Only $900 each! Get a couple for the kids!I'm going to be awake dreaming about and lusting after one of these with all that technology! At least they kept the waxing on about the build to stuff that is understandable and not in weird terminology and stuff that means absolutely nothing in physics terms. I perused the iFi website and yes, it is shameful that a company with the offerings it has went as low as power cord/cable hype. Despicable!
This just further reinforces my suspicion that the “tastemakers” in the industry, the writers at Stereophile or “professional reviewers” on YouTube or other corporate-funded websites—the ones that parrot this sort of marketing claptrap—have far less technical knowledge than their highbrow prose suggests. Same goes for a significant number of self-described “audiophiles” on Head-Fi (or the unfortunate “reviewer” from Amazon referenced earlier in this thread)—they launch right into their subjective assessments of these “features” with no a priori curiosity or due diligence into whether these terms defined de novo on these manufacturer marketing tear sheets and website descriptions even mean anything.They say
If that worked, a cable like that would be nice to have for a bunch of PC owners whose power-hungry GPUs can really mess with the device's ground potential... well, not at that kind of price obviously.
Problem is, I don't think it would be very suitable for applications that demand substantial current, due to the series resistor involved. So not sure what they are doing, if anything.D-Noizator: a magic active noise canceller to retrofit & upgrade any 317-based V.Reg.
D-Noizator: a magic active noise canceller to retrofit & upgrade any 317-based V.Reg. ✪ A simple circuit that transforms a good, clumsy workhorse like the LM317 into a superreg so easily that you do not even need to cut a single track. ✪ ✪ It must be too good to be true.... or ✪...www.diyaudio.com
