KSTR
There is a small error coming the directivity of the measurement mic at very high frequencies (it loses its omnidirectional properties) but that is usually not significant as it affects the upper HF response only at very large vertical off-axis angles. In a perfect world the Klippel NFS would tilt the mic so that it always points directly to the tweeter, mechanically. Post-correction (when the angle and the directivity is known, the impact can be factored out mathematically) would be simpler, though.Looking at how the NFS mechanism work, I may have been mistaken. It looks to be moving the microphone up and down without changing axis (I was assuming it tilted as it moved around somehow). So it actually did capture the on-axis measurement of the woofer as well if I understand it correctly. I was assuming the microphone tilted as it moved around the speaker. So you actually don't need to remeasure. It's a matter of just selecting what is reference axis from the existing measurement/data?
