By the way, to point out the (mostly) obvious, an SET-type amp will behave very differently into a more complex/difficult load, like a real speaker. This is possibly where the SET "magic" occurs
Its not.
SETs sound their best driving
easy loads,
not difficult loads! One thing to keep in mind is that the tech is so old that the voltage rules most people take for granted had not been adopted. They use 'power rules' instead. Back in the old days, speakers with weird phase angles didn't exist!
So the speakers with which SETs are typically used will have a midrange and tweeter level control to allow the speaker to be adjusted to the power (not voltage) response of the amplifier and otherwise a simple crossover.
These days the adjusting is best done with pink noise... in the old days it was done by ear. A lot of people think those controls were to allow the speaker to be adjusted to the room but they are really for the amp.
Another thing to understand about SETs is, having no feedback, they are high distortion at full power. To that end, they really should not be used past about 20-25% of full power (IOW -6dB) because right at that point is where the distortion, in particular higher ordered harmonics, tends to take off. Since music has lots of transients, the additional higher ordered harmonics will show up on the transients, giving the amp a 'dynamic' quality due to how these harmonics interact with the human ear. If you read up on SETs, you'll see a lot of people talking about this 'dynamic' aspect. What's really happening is the speaker they are using is not efficient enough to keep the amp below that -6dB range. Truely high efficiency speakers are rare and really expensive because so much more precision is needed to build the drivers. These days speakers like that might be five figures... so most of the time, SETs are coupled to speakers with which they really have no business if you want to 'hear' what they are about.
BTW in case its not obvious, I see no reason for SETs; there are very good reasons they went away. SET lovers talk about how PP amps don't compare and when they talk about that, usually the PP amp is entirely different tube types and a lot more power. If you make a PP amp the same power, or use the same power tubes the SET uses but in PP, you find out that the SET has nothing whatsoever over more modern amps. This is the sort of thing that is easily measured and easily heard, so no matter what camp you come from, measurements or subjectivist, the conclusion is the same.
Mathematically SETs express a quadratic non-linearity, which is to say that H2 is the dominant distortion product with higher orders falling off on an exponential curve.
If the amp is fully balanced, a cubic non-linearity is expressed which has higher orders falling off at a faster rate (also exponential) with the order. This is simply because less distortion is compounded from stage to stage.
I think where the SET guys get in trouble is the PP amps they compare to typically combine single-ended and PP circuits, which tends to cause an enhanced H5. Crowhusrt wrote about this 65 years ago... those guys are
at least that far behind the times.
I've found that SET lovers that resist this idea simply have not caused their hand to move and see what's out there...
