Ignore the SPL numbers in the legend for all of these. You just want to look at the "shape of the curve".
I have recorded these using a resistor. Take a look at these REW sweeps at different dBFS. Except for the power supply noise getting into the 60/120Hz range, you don't worry too much. It looks similar.
Now look at the
JBL XPL90 which has been measured here and look at the different results depending on the dBFS sweep. Again, ignore SPL -- I just ran the sweep and kept telling it to go -10 dBFS each time.
Note that the 300B does the opposite of a loudness curve. You get extra treble boost with higher energy, but at low volume, the treble increase is lower. This is all from a ton of distortion that's happening. There is even a bass boost at lower volumes. ALL distortion. But at least amongst 300B fans, the right "pattern/character/flavor" of distortion.
Now we're starting to see the effect of the SET and its role as an effects box. You cannot turn it on or off, but a simple Parametric EQ isn't going to let you replicate the "tube sound". You can pick one treble boost for the entire song, not a dynamic one that depends on the content.
We know the "showroom sound" can be fun for short periods of time, but the boost can be fatiguing. But you have to think about this in musical content. The showroom sound comes only on demand during transients! So imagine having an effects box where the effect is subdued in the normal parts and during transients, it jumps up even more.
This is also the challenge of recording the SET. You not only have to think about the actual speaker but all the volume it's running at.
Take a look at the slope of those REW sweeps. We start to see the rise at 3 kHz, right? Lets see what
@amirm measured on the XPL90.
Do you see something at 3 kHz also? I don't know why we don't see as big of an effect in the bass, but remember that I'm not using a simulated speaker, I'm literally playing back through a speaker so maybe back EMF plays a role, since damping factor for SET is really low.
What's really neat is that if I take a few different 2-way speakers that I own, and eyeball-match to 1 kHz the SPL, we see that the relative to the resistor, you get a pretty consistent bass boost which is almost always snazzy while the treble gain differs between different speakers, but really does counteract the "rolled-off" highs that measurements can. I ran these off the 4 ohm tap, though they are all 6 ohm nominal.
