fpitas
I've heard good tube amps that sounded nice like SS. But they had beam-power tubes in push-pull ultra-linear, so obviously my hearing is defective
If the taps are properly placed on the primary winding, the linearity of the output section will be as good as the best triodes. But usually the taps are misplaced out of tradition, since in the old days that was done to get around a patent (which has long since expired).I've heard good tube amps that sounded nice like SS. But they had beam-power tubes in push-pull ultra-linear, so obviously my hearing is defective![]()
I've seen designs that have nested feedback, back to the driver cathodes, as well as to the input. But I have no idea what this amp did. It was an expensive amp for the time (1970 or so) driving KLH Model 9s.If the taps are properly placed on the primary winding, the linearity of the output section will be as good as the best triodes. But usually the taps are misplaced out of tradition, since in the old days that was done to get around a patent (which has long since expired).
The other tricky bit is how to apply feedback. Usually its applied to the cathode of an input tube, which causes the feedback to be distorted. It seems best to mix the feedback with the incoming signal in the way that its done with opamps, but of course no-one does that. As a result a lot of the 'sound' of such amps relies heavily on the linearity of the input tube...
And they certainly don't normally listen like this: "I just chose a short segment and kept running shootouts over the same segment. "The vast majority of humans don't hear that well, so you should wonder.
I tried this test with a good pair of earphones and made my choices of which I liked best. However, then I started wondering if I actually could tell the difference or if it was just self deception so I loaded Lacinato's ABX tester (which is great!) and tried again.
What I found was that my original ranking remained, particularly if I just chose a short segment and kept running shootouts over the same segment. Using the same segment, I was quite consistent, about 85%. With different segments each time it was about 70%. Now I'm very curious to see if I actually like the tube sound.
However, I was quite surprised at how similar the two versions sounded considering the seemingly huge difference in SINAD rankings. It does make me wonder about the claims of being able to clearly hear the difference between an amp with a SINAD at -76 and one at -86.
Still, we know that some people can hear to -300dbIt makes me wonder about the claims of being able to hear the difference between cables, cable risers, speakers with 20 hours of "burn in" vs 60hrs, dacs, etc etc. lol
Would depend on the design and above all the load would it not ?in particular an SET, is bass response, not high frequencies.
I think I do know what GBW is and what feedback does.. until someone can find a way to convince me feedback is a bad thing and open loop BW should always be at least 20kHz.To understand this, its helpful to understand what Gain Bandwidth Product is, and how that's important when dealing with an amplifier using feedback
That may well be so but the distortion would be substantial and will become lower when feedback is applied. Of course with BW limited components (transformers) that add distortion into the feedback loop it can go in all directions depending on the design.So when you graph distortion vs frequency, you get a flat line across the audio band
In the case of this amp I am quite sure people will have a hard time preferring the tube amp over the wire and vice versa. All people that reported talked about the treble roll-off as a give away. Remove that and only the distortion remains is my point.So this supposition is incorrect, unless the load in the highs for the SET is lower in impedance than it is in the midrange.
Right? I kind of wanted a hi-fi, not a re-processing facility.Not all people like to have the sound changed in some way.
People set the listening volume to get the RMS (LUFS) level they want. They don't care about the peaks, in practice.When you make the RMS values equal, then the peaks are different and you might be able to hear the difference in the transient/impact.
This is very interesting !Fair Use Statement:
The copyrighted material is being used for research and scholarship. Less than 10% of the total length of each piece is used. Commercial recordings are required for this experiment to reflect the types of music that one would really listen.
Is that really enough ?
Could you link to some page that confirms that ?
Is that valid outside of US ?
That's been some time I wanted to do something similar, but the copyright topic was blocking me.
Thanks !
Did the following thing:
Used @danadam level matched uploads, added an approximate of the treble + bass difference found by @pkane to the files that needed it and created ZIP files.
For those who like to hear the difference between the original and the SET amp without the subbass (-1dB) and treble (20kHz-4dB) roll-off, as that roll-off should be almost completely eliminated, leaving the added harmonics, IM, noise and hum as the only things that can differentiate the files.
Maybe @pkane can check if I did the job correctly ? My ears tell me I did but am just as prone to bias as the next person.
I want the sound supplied to me 'as it is', i.e in high fidelity to source...so I can have my way with it.Right? I kind of wanted a hi-fi, not a re-processing facility.
Again, its highly unlikely that the SET has an audible treble rolloff, unless you're saying that rolling off at 25-30KHz is going to be audible. Have you ever put an SET or for that matter, tube amplifier on the bench and measured bandwidth?? I get the load dependent issue but in tube amplifiers that was solved 60 years or more ago by the application of feedback so as to get voltage source operation out of the amp.In the case of this amp I am quite sure people will have a hard time preferring the tube amp over the wire and vice versa. All people that reported talked about the treble roll-off as a give away. Remove that and only the distortion remains is my point.
The amp in question, like many of these designs, are highly load dependent.
People may like/prefer that (depends on the speaker, amp, music and individual)
Is that the one that's "controversial" because it's not a conventional single-ended design?W-E 91E 300B amp just arrived (and holy crap that thing is big!). It arrived in a steamer-trunk style crate. This will be interesting.
Unfortunately, I will not be able to divulge results until after the review (which will be written by Richard Honeycutt, I'm just doing measurements) appears. However, I'll be happy to share my personal sonic impressions after the review is out, and I'll see if I can get permission to post a recording of the output into an actual loudspeaker load versus the original source material.
To get around the problems, challenges with tube amps and their inability to power bass drivers:Yes and no: all SETs lack the LF response really needed to get the bass right. This normally is not a weakness since the speakers needed to work with them generally can't make bass either, unless they are very very large (IOW enormous horns...) and yes the load is important but in that context. If the load sensitive issues are not given attention you can't get the amp to really do what its meant to do. Keep in mind that the idea of voltage drive came in during the 1950s and SETs come from several decades earlier, when everything was done with power drive rather than voltage drive.
I'm not saying feedback is bad!! But it can have bad effects if poorly applied. Open Loop bandwidth will need to be a lot higher than 20Khz or else you'll need a ton of gain... your comment here about 20KHz is ambiguous- did you mean that to say unity gain or -3db or -0/5db??
I previously explained a common problem with feedback if the GBP is insufficient (and in most cases of amplifiers made, it is). Here's another: if the feedback is applied to a non-linear node (such as the base of a transistor in a differential pair or the cathode of an input tube) the feedback signal will be distorted by the non-linearity of the device. This in turn contributes to higher ordered harmonics, inharmonic distortions and IMD. These things are audible and are a very good reason why SETs are so annoyingly still around (since re-emerging in the 1990s). Norman Crowhust wrote about this a good 60 years ago so this should not be controversial in any way.
It is not my intention to derail this thread on this topic.
Yes the transformer is bandwidth limited, but the point of feedback is to deal with distortions at the output of the circuit and this of course includes that which an OPT might make (which, if properly loaded, will be fairly low). Perhaps you might want to retract this particular statement?
Regarding the bandwidth thing again- many tube amplifiers are full power to 100KHz (H/K Citation 2 and Citation 5 for example). 50KHz is very common (Dynaco, Marantz, ARC and more). I'm just wondering why you think this would be audible in the treble range.
Again, the reason tube amplifiers seem to have less energy in the treble range is not due to a rolloff. Its due to how they make distortion as compared to how traditional solid state amps make distortion. This is easy to see in the measurements as I pointed out earlier.
