Your way of looking at it ("after how many milliseconds the x-axis is intersected during the step response") is, as has been said several times now, much too simplistic and naive and tempts others to adopt this shortened representation as well.
With
@bennybbbx I have already given up hope, but perhaps the following shows others that the step response often does not tell you much and often the wrong thing.
Let's start from the Step Response in the Stereophile.
According to
@bennybbbx, an extremely fast speaker:
Source:
Stereophile.com
The crossover frequency to the woofer is 330Hz and the step response shows that the woofer is connected phase inverted.
Thus, it is obvious to assume a 2nd order crossover.
Now we simulate the crossover with ideal drivers:
It does look quite similar. So, now let's deactivate the woofer and just look at the Manger driver:
OMG, if the woofer is deactivated, then the manger driver slows down and crosses the x-axis later!!!
This is of course total nonsense, nothing has changed at all in the decay behavior of the Manger driver.
Now we get completely cocky and look at the Manger driver's step response without a crossover:
Source:
troelsgravesen.dk
WTF, what is this lame sh..t! By
@bennybbbx's definition, this would be a driver for the trash can.
Unfortunately, the usual CSD is missing from the Stereophile Manger S1 review. But you can find a CSD of the Manger driver at
troelsgravesen.dk:
In the frequency range above 3-4kHz the Manger driver shows a good decay behavior, the resonances visible in this range decay very quickly.
Below 3 kHz there are severe decay problems. In the range 600-800Hz there is a bad resonance that needs at least three to four oscillation periods up to 25dB damping (maybe even significantly more, this can not be said clearly, since several resonances run into each other).
There is no use in making up nice advertising stories for "audiofools" and hobby sound engineers about transients when the speaker does not deliver on these promises. To stay in the advertising language, how should such a loudspeaker cleanly separate transients in the midrange, if they still resonate for a very long time?
For comparison, a loudspeaker that shows very good decay under the same evaluation conditions.
After about 1.4ms the speaker is damped by 25dB down to 400Hz.
The Manger driver needs 2-3 times as long in many frequency ranges.
Even if the numerical values should not be taken too precisely, the differences are extreme.
View attachment 117032 View attachment 117033
Source:
troelsgravesen.dk
Who would have expected such a "fast" behavior from this speaker when looking at the step response of the woofer
Therefore again, the interpretation of impulse response and step response which quite a few do is very often "esoteric science".
A good book like "Testing Loudspeaker" by Joseph D'Appolito, Arta Handbook and Manual and the simulation of different filters and crossovers with free software saves one from false simplifications (but one must plan a few months of study time).
