Johan Liebert
- Joined
- Mar 9, 2020
- Messages
- 47
- Likes
- 17
Other than impedance(material and gauge and length of cable) being the most important measure and maybe some shielding(not even sure if this is that important) and nice contacts(gold plated banana plugs, spades, speakon connects etc, is there any other thing that matters in speaker cables from a measurement perspective?
I sorta though that's all that mattered from a measurements perspective and then I read the Benchmark AHB2 thread where John Siau from Benchmark talked about Star-quad geometry and linked here.
https://www.audiosciencereview.com/...of-benchmark-ahb2-amp.7628/page-7#post-178989
It's been years since I last took fields and waves. The idea that the conductors parallel to each other carrying the same current/signal in the same direction is helpful since the magnetic fields created by them will be cancelled but I'm not sure what's the problem with the spacing between conductors.
I don't necessarily understand how a normal speaker cable may create a LR lowpass filter which rolls off the highs, if it does I guess is more exacerbated by the longer the cable length is.
That being said if I ever decide to get a Benchmark AHB2 or 2 their NL2 to Banana speaker cables aren't nuts to obtain or crazy overpriced.
