Looking better than 90% gear nowadays.
My speakers are DIY Soundgroup 'Tempests". they're about 98 dbl efficient, so a pretty easy drive. sorry to say the kits aren't available anymore, but the parts might be. They were designed by Jeff Bagby and he's no longer with us, so I feel kinda fond of them. Iwas biasing to around 62 ma. My wife, who has the same setup as me, loaned me her WE 300Bs to break in, so I went on the WE site and found out they could be biased to 100 ma. I went to 75ma and they stated to sing. Previously they were kinda dull sounding and all midrange. I actually thought my Gold Lions had more life. She's since taken them backI have a bit of time each week to try measuring stuff. Since my DAC isn’t so straightforward I can do a series of tests at different voltages and then increase in a stepwise fashion. That said, tubes are a really bad idea when you need lots of power.
I made this chart in a different thread where I show my work for the calculations which sort of shows in both directions why tubes work well for moderate listening levels and why “even though a watt gets you a lot of output, you still want 300-600W juggernaut amplifiers if you are playing music with bombastic peaks.
Speaker dB at 0.05W (5 vs 15 ft) dB at 0.5W (5 vs 15 ft) dB at 5W (5 vs 15 ft) dB at 50W (5 vs 15 ft) Revel PerformaBe F328Be 80.3 / 70.8 90.3 / 80.8 100.3 / 90.8 110.3 / 100.8 Focal Aria 906 76.3 / 66.8 86.3 / 76.8 96.3 / 86.8 106.3 / 96.8 Elac Uni-Fi 2.0 UB52 72.3 / 62.8 82.3 / 72.8 92.3 / 82.8 102.3 / 92.8
Peak advertised power handling
Speaker Peak Advertised Power Handling In room Peak SPL (5 vs 15 ft) Revel PerformaBe F328Be 300 watts 118.1 / 108.6 Focal Aria 906 120 watts 110.1 / 100.6 Elac Uni-Fi 2.0 UB52 140 watts 106.8 / 97.3
I don’t know if this actually measures better than a MC275/MC2102. From what I understand the 12ax7/12at7 combo is even better than the 6DJ8. Then the question is how good something like an Audio Research, current production amp can perform.
Definitely! Searching USPTO, I cannot find evidence that they ever trademarked the name and Sega has trademarked the name for their latest Sonic the Hedgehog game.
I’d love to hear a 300B system. It sounds like the power limitations are real, but with a matching high efficiency speaker or appropriate listening level, it’s supposed to be very impressive.
You should put your gear on the test bench too. I have always been told that higher biasing is better too, but I subjectively thought 40 mA was better but I also told myself that it was probably the bias of knowing that these tubes have a finite lifespan and have no reliable replacement.
But at least in this case, the lower bias measures better! The 6550A should easily handle even more power than 50mA. Then you have all the hand waving that EL34’s sound better than 6550a’s if you don’t need power, but EL34’s are typically biased at 40 mA.
I don’t use this tube amp in any of my primary systems but it might be interesting to see if 42 mA, 45 mA, or 47 mA ends up having the “best” results. I just have two datapoints.
No matter how good your 300B setup may be, it would be nice to see if there is a sweet spot for your bias. Certainly, the new current production 300B’s from Western Electric would be interesting to measure.
Remember that my measurements are as much as 9 dB worse than what Amir can get with his carefully designed setup. Still, my 5W SINAD of 74 dB is pretty impressive. It means I'm beating the Lyngdorf TDAI-3400, Anthem MRX520, Pioneer Elite VSX-LX504, and every tube amp tested to date at ASR. I don't know if we'll really get the full 9 dB when measured on a proper setup, but I'm very confident that this unit would break past the mean amplifier SINAD of 78. If this amp can break into the 80 dB range, that really would be saying something about the types of audio gear being passed off today as "audiophile premium products" wouldn't?
If Multitone is used, I recommend to display FFT results in dBr - otherwise THD value is not correct (is calculated relative to 0 dBFS, as the SW author has explained).Great job again, @GXAlan! You are doing what I didn't dare to try so far: measuring amps with the Cosmos!
As many pointed out in my former reviews, maybe REW should be more accurate for THD+N figures. I personally use :
- REW for 1Khz THD+N and DR.
- Multitone for... Multitone (yup!) and Jitter (the latter not being a thing for amps)
- RMAA PRO for regular tests: FR, Noise floor, SMPTE IMD and Crosstalk.
You started this Train rolling. Just sit back and admire the fruits of your inspiration. Snowball effect! Every measurement adds to the collective knowledge library. Great job @GXAlan.Pretty soon I can stop doing reviews.... Promoting to home page.
Well I think that is essentially reason Sonic Frontiers folded -- just foo many people felt that way.*Raises hand.
I'm in the "if I wanted solid state sound I'd buy a solid state amp" camp.
(Actually, I did also buy a solid state pre-amp. I like it and my tube preamp).
Beautiful preamp!
Only if it used 6SN7 dual triodes in cascode.Not unlike incense and holy water, the enthusiasm for tube equipment mystifies me. But, of course, it seems harmless, albeit distracting. For me, I expect vacuum tube devices to go the way of whale-oil lamps. Curiosities for certain, but no longer suitable for everyday reading and commerce.
Well, carry on. It's a bit like organizing a St Patrick's Day parade: useless but basically inoffensive. And a distraction from the mundane modern-day devices that run unattended for decades and which we now take for granted.
Would you ride on a 20-story elevator powered by vacuum tubes? Even one with a full-time tech measuring grid biases
So why is this tube amp particularly "good" otoh?
So based only on SINAD at best measuring level, your measurement rig doesn't add anything to your measurements up until aprox. 100db SINAD.
Wow! Did they publish the paper anywhere? It would be great to see the tubes and bias that was applied.BTW, the best measuring tube amplifier at least i have ever seen is a unity coupled design based loosely on mcintosh mc60, designed by technical university berlin with the only goal to be the best measuring tube amplifier. They got to 88db at 0.56W, -82db at 9W and -71,5 at 44W.
@GXAlan if you intend to keep on reviewing amps, you can set up a fundraiser and users here can help buying 4 ohms resistance and a DAC.
Edit: same for @VintageFlanker for resistors.
Understandable as your personal point of view. I don't read much about old sports cars. Don't know why anyone likes 'em.Curiosities for certain, but no longer suitable for everyday reading and commerce.
It's not online anymore, but downloadable, at this third party website: https://nanopdf.com/download/der-unity-coupled-verstrker-nach-mcintosh-mc_pdfWow! Did they publish the paper anywhere? It would be great to see the tubes and bias that was applied.
It isn't really. You'll get used to it.
But as you are testing amplifiers, we really need to know what they can achieve in terms of power output.
It looks very nice, but the sheet metal and tube cage metal is pretty thin/flimsy compared to McIntosh. It's a smart move overall because it saves money and doesn't affect the sound quality but it makes shipping the units extra hard because it's so disproportionately heavy and I can see the transformers denting/deforming the sheet metal and tube cage against its own weight.Sonic frontiers stuff always looked so nice and was semi reasonably priced compared to its competition. You can pick up nice pieces affordably these days if you are into nostalgia.
