SMSL M500 DAC and HP Amp Review
jani80k
get a lightning to USB adapter
SMSL-Mandy
Connection question - How to connect an iOS device to the SMSL M500 DAC?
svengun
Dutch guy living in Barcelona
I recently bought a Denon DNP-800NE (network streamer) , which uses a Burr Brown PCM1795 DAC chip. I was recently on holiday and read up on that chip and most what I read was, that the Sabre ES9038PRO , is more recent and a lot better. The Denon supports an external DAC via Toslink (optical)
So, I'm considering to buy the SMSL M500 , but only if it will have an audible improvement. I know audible is up to anyone's own perception , but I'm open to educated guesses / opinions
I read on this thread (posted by a user) that streamers like Denon, Yamaha (etc) usually use 'good enough' DAC's ,so this , plus my research on the DAC chip in the Denon , made me think of going this way
The link would be NAS (DNLA) > Denon streamer > SMSL DAC > Cayden Tube Amp (CS-88A) > Klipsch RP6000f tower speakers
Many thanks in advance, for any advice !
NorthGraves
Buy where you can return.
1) An audible improvement or not will depend a lot on who you ask
2) It'll depend on the audio path including the source as well
3) I would be skeptic about ES9038PRO sounding A LOT better than PCM1795 (and I have an M500 and a couple of Burr-Brown based DACs)
4) To play native DSD 128/256, I think you need a USB streamer, like Zen Audio Stream, I don't think you can stream native DSD over Optical/Coaxial outputs on your Denon
5) There are other considerations, like M500 having balanced outputs + able to decode MQA etc.
svengun
Thanks ! considering that you own devices with these DAC chips, I'm gonna go with your advice (DSD playback, MQA en XLR's are not important to me, at the moment)
I need to chill with my audio upgraderitus , already spend 2500+ euro's in a month's time on improving my audio, which wasn't planned at all and I'm not a rich guy ;-)
the Denon streamer + (and because of) the tube amp , already heavily improved my audio quality, with new, unheard details and smoothness (it formerly was PC with 100$ soundcard to Marantz SR6010 > Klipsch RP6000F's)
Laserjock
Texas Coastal
Get the one with lightning power input option. Apple Lightning to USB3 Camera Adapter
The other may work for some but mine required power when I tried it.
Buy once
Killingbeans
Bjerringbro, Denmark.
Personally I wouldn't feel the need for an external DAC. The likelihood of an audible difference is very low (to put it mildly).
[prejudice] The tube amp and the Klipsch speakers are probaly also "colorful" enough to dwarf anything of importance :D [/prejudice]
svengun
So a ' much' better SINAD (e.g. 90db to 120db) will probably not be noticeable, because of the colorization ?
If so, OK, Thanks !
Killingbeans
Well, the types of distortion you get from speakers are different from what a DAC would display, so they probably woudn't mask it directly. The tube amp is a different question. Depends on whether it's designed to have "tube sound" or not.
But still, hearing differences at -120dB requires specialized testing under optimal listening conditions (probably headphones) and with lots of prior training.
With a normal speaker setup in a normal room, the point of complete insignificance is most likely reached at -60dB (that might even be a generous guess). Especially when the music's playing.
If you ask an engineer, audio DACs was a solved problem pretty much at the get-go. There are truly terrible implementations out there, but then we're talking $2 converter boxes from AliExpress, or "boutique" DACs that are deliberately mangled with audiophile phobia/anxiety in mind.
Sometimes you'll come across a guy who'll explain to you that he is deeply bothered by stuff at -300dB, but then he just happens to have a multi $1000 box that can make it all go away :D
svengun
It's my 1st Tube Amp , I believe it is designed to be more neutral. Quote from a review: This Cayin is lush, natural, vibrant and alive in midrange warmth. It is not a dull amp at all and the sound is very timbre correct and natural. The CS-88A Mk2 features smooth and extended highs - sparkling clarity, yet without that ear surgery "bite". There is a balanced midrange
I do know that the Klipsch are not neutral & Amirm really dislikes them ;-) (I also have the RP-160M , which got an awfully negative review here. My Setup was Home Cinema first, but now I have separated it via an AMP+Speaker switch) Sorry , went a bit off-topic, but the Klipsch review always bothered me , read it shortly after my purchases :confused:
Killingbeans
Perfect example of why I don't put much value on reviews. This one seems to contradict itself 4 or 5 times :D
The product page says: THD 1%(1kHz), but doesn't specify the power level.
Doesn't smell like an attempt at designing a neutral amp to me. Not that it matters much, as long as you enjoy it.
NorthGraves
FYI, got an iFi Zen Stream today (for 90% Tidal/10% Internet Radio) and seems to work fine with M500.
Displaying MQA on M500 when playing Master tracks.
In case you are considering:).
MalinYamato
東京都世田谷区
thats the way to go. also I go for Zen, I run Volumio3 on a NUC that feeds into M500, that feeds a Zen Can V2 and I enjoy Tidal MQA that way. The thing with M500, since the display is large everyone around me and at a distance knows that I listen to MQA stuff and what gets out from my headphones is no crap. :) Some complain about MQA as being lossy, but to me it sounds great and for everyone else there is no audible difference between listen to MQA and a non lossy FLAC that encodes the original master, not at all.
reddeath
Hello All,
I have a SMSL M500 (V2, SW: 1.6, HW: 1.3) for nearly 1 year now.
Just recently, when placebo effect has worn out, I have realized that the built-in headphone AMP produces much thinner bass frequency for a given song than my other amps I have at home. Song tested, among many others, is: Bassotronics - Bass, I Love You.
All the below combinations produce a nice filling bass at the same subjective volume levels, as opposed to SMSL M500 headphone out:
- Logitech Z-2300 headphone out. Sound path: PC USB (Tidal master or foobar) => SMSL M500 RCA out => Logitech Z-2300 headphone out
- Denon AVR-X4500H. Sound path: nVidia Shield TV HDMI (Tidal master or Kodi) => Denon AVR-X4500H headphone out in Direct mode
- Zen Dac V1. Sound path: PC USB (Tidal master) => Zen Dac headhone out (no bass boost)
Headphones tested (all around 50 ohm):
- Bose QC 35 II
- Sennheiser HD 599
- Sennheiser HD 558
SMSL M500 volume levels:
- Headphone out: 10-12. Increasing to 20 does not give more base, and it is too loud.
- RCA out: 20
So far I have not heard a single review mentioning this issue - lack of bass where (presumably) there should be a nice oomph.
Can anyone confirm or deny that their M500 has similar issue, based on comparison with other headphone amps?
MediumRare
Chicago
Hello All,
- Bose QC 35 II
- Sennheiser HD 599
- Sennheiser HD 558
- RCA out: 20
Since it's extremely unlikely those other amps have as much power or low distortion as the SMSL, perhaps you are enjoying the increase mid-bass from harmonic distortion those other amps likely produce? I can't tell you to prefer cleaner bass over "more"/dirty bass, but that does seem to be the likely situation, IMO.
reddeath
I should reformulate my statement to avoid misinterpretations and ensure that potential replies of M500 owners benefit the readers of the forum, including myself:
My observation is that M500 lacks loudness in the low frequency, where there should be much more present. it is just very thin. I don't hear any distortion on the other apms I listed that I used to listen to the same songs.
I posted the same question on the M500 owner's thread on this forum, but there has been no replies there so far. Should I assume that many people on this thread are not owners of M500 and just post here for fun?
MediumRare
Chicago
If there were distortion, you wouldn't hear a buzz, you would hear additional frequencies that are perceived as a thickening of the sound. E.g. 40 hz as +80 hz, +120 hz, etc. It would only sound like a little more bass.
reddeath
I will take it as a possible theory. Do you own the M500 by the way? Do you own any other amps to compare them?
I should also underline, that M500 is the DAC used in one of the testing paths I have described, where using either an RCA out or XLR out from M500 going to the Logitech Z-2300 (old school TXH certified, class AB) active speaker setup with headphone out, I am getting much fuller (better sounding) low frequencies, compared to M500 headphone out.
