How do these filters map to their respective names ... e.g, minimum phase, apodizing filter, etc
There's a whole tread on the SMSL mislabeled filters.
Several SMSL DACs using versions of the ESS ES9039 chip have mislabeled filters. First, I will use the case of the DL200 using one ES9039Q2M chip to show this is the case and correctly identify the filters. Then, I will show that other SMSL DACs using ES9039 chips namely the D-6S, DO100 Pro and...
www.audiosciencereview.com
I can't say for sure which names of the mislabeled filters were corrected. At the time I did measure the DO400 (
not D400EX) the situation was like this:
SMSL FL1 - Off
SMSL FL2 - Minimum phase (ESS #1)
SMSL FL3 - Linear phase apodizing (ESS #2)
SMSL FL4 - Linear phase fast roll-off (ESS #3)
SMSL FL5 - Linear phase fast roll-off low ripple (ESS #4)
SMSL FL6 - Linear phase slow roll-off (ESS #5)
SMSL FL7 - Minimum phase fast roll-off (ESS #6)
SMSL FL8 - Minimum phase slow roll-off (ESS #7)
Many of the filters can be distinguished easily:
- symmetric ringing (pre-and-post ringing): linear phase
"only" post-ringing: minimum phase
- fast roll-off: a lot of ringing
slow roll-off: little ringing
The "low dispersion" filter shows this weird (not exponentially decaying) pos-ringing
