SMSL D400EX DAC Review
Rate this DAC:
    Votes: 11 3.2%
    Votes: 21 6.2%
    Votes: 121 35.5%
    Votes: 188 55.1%
David_M
It includes balanced operation, a leading DAC IC, very nice casework and some goofy fonts at the display. For $1k it's actually very good.
Simply- because that is what they think they can charge to maximise profit.
Ok... but looking at the SMSL DO300 or my new DO400 (essentially a do300+HP amp) at half price, all 3 devices using the same SOTA 9039 dac, I still fail to justify the $1000 price.
Jimbob54
I can't disagree. Pick a modern dac on looks, connections and functions at the lowest price you can get if its been measured as decent.
Doodski
I bought the JDS Labs ATOM DAC+ and called it a day. It works fine and cost me very little. So a thousands dollars on a DAC like this is not attractive to me. But it is a nice DAC for sure and specs out veryyy well.
Johnny Fire
Greece
hello. i have the DO400 and i love it so far, i pair it the Airpulse A300 speakers using XL:R and seem the i have some clipping higher than -1.0db
so i use -2.0 to be sure and sound clean and nice!
i suppose the speakers dont support 5V but on Topping D90SE i was used in the past had a setting to set the XLR 4v (4.2) and 5v (5.2) by user
the quick question is: is the -2.0db the right volume to get the proper 4V or like -1.5db?
thank you in advance!
staticV3
the quick question is: is the -2.0db the right volume to get the proper 4V or is it higher like -1.5db?
The DO400 puts out 5.23Vrms at 0dBFS. To limit the output to 4.0Vrms, you have to set the volume to 20*log10(4/5.23)=-2.33dB
Johnny Fire
Greece
The DO400 puts out 5.2Vrms at 0dBFS. To limit the output to 4.0Vrms, you have to set the volume to 20*log10(4/5.23)=-2.33dB
and if its 4.1V? to be sure because toppings 4.1V works in my case cant set it to -2.33dB so -2.50db for 4V
Kiko1974
I own an SMSL DO 300EX that uses the same AKM chipset that this DAC, only that only features ONE AK4499EX chip.
I have some questions regarding this chipset combination.
Sound colors: I don't think this is an equalization feature in the same way Sabre chips do. In the user's manual of the DO 300EX is stated that Color 1 and 2 make the AK4499EX work at 5.6 MHz, that's 128 x oversampling, and Color 3 and 4 make the AK4499EX work at 11.2 MHz, that's 256 x oversampling. So my conclusion is that how the AK4191 modulates the incoming data, either PCM or DSD changes the sound of the AK4499EX. Am I right?
I personaly prefer the default Color 1 to the others as I think make the AK4499EX artificial or tiring. Color 4 for well recorded Rock music sound is dull and lacks punch.
Another question is DSD's filters, Wide and Narrow. I guess Wide reproduces DSD unfiltered, ultrasonic sound and all, and Narrow filters DSD to avoid ultrasonic noise to get to the amp and speakers. But AKM has no information about at what frequency does the Narrow filter cuts off. Any info about this?
