This is the VTV with the stock Ncore buffer.
Your xlr screen is also incorrectly wired.This is the VTV with the stock Ncore buffer.
Pins wired wrong? I think it's in upside downYour xlr screen is also incorrectly wired.
No its not that. The screen shouldn't go directly to pin one, it should go to chassis elsewhere.Pins wired wrong? I think it's in upside down
Which isn't reliable hence the push on connector tab.It appears to be counting on the filter body contact from snapping into the back panel.
Any comments on the orientation of the power supply to the amp modules? Is any shielding necessary? How about heat sinks? Does the power supply need them?Please Note my vested interest here but these are genuine observations
No earth connection. The mains wiring doesn't confirm to class 2 standards so it is required for safety. Add it in yourself for your own safety.
Speaker post soldering quality.
XLR screen incorrectly wired.
General wiring routing and hygiene. Yes it matters. Tight twisting required to minimise switching radiation and pickup.
It's a simple fix for you to do yourself but it should never be sold like that. It's potentially dangerous. The manufacturer clearly doesn't have adequate electrical safety knowledge. From the observations above lacking electronics knowledge too.No I haven't checked earth connection. Pin 1 wire just goes to the square connector on the buffer board.
I think "sub optimal" covers it Those inductors right next to the amp module.Any comments on the orientation of the power supply to the amp modules? Is any shielding necessary? How about heat sinks? Does the power supply need them?
Try this: http://pin1problem.com I always found the Rane paper most useful.When I look up xlr pin 1 problem I found this. Looks like audio ground is different than digital ground like a computer https://electronics.stackexchange.c...nd-mesh-ground-and-contradictory-grouding-pra
I contacted the owner of VTV and his response is this:
“Yes there is no pin one problem. The chassis is ground led to earth and the modules audio signal is not. That is what Hypex directs.”
(I mistakenly did not specify Purifi in my email contact, but he ensured me in a follow up that it works the same)
I also purchased a Purifi amplifier from him with stock Hypex board, I haven’t received it yet.
OK, now I'm even more confused.
Please ask, "Where exactly is Pin 1 tied to the chassis?" That will be a harder question to evade.
