Well, if any , ANY, of the local shops were competent to demonstrate XT-32, I might consider a Denon. But as it stands, I doubt I would get any better sound than my Anthem running 5.1 over S/PDIF. My room can only support 5.1, or with some great effort doing some re-framing, maybe front ceiling, 5.2.1. ? I almost got enough CEC working that a new AVR with HDMI 2.1 is not that big a deal as the TV is handling it. I did just get the audio switching glitch again, so continuing to monitor CEC and HPD lines. I would prefer to pick a slightly different top end eq than ARC does, but it is not big. Dirac or XT32 are supposed to allow such but I have not seen it. The Anthem does have very good amplifiers compared to most. DACS should have gotten better, but my Amirm's testing, not so sure of that either!
The point I made on the Onk and Pioneer is the couple of new ones with Dirac if, and only if, they were full spectrum. Once upon a time, they made decent gear. The NAD is at least honest in telling you they charge another buck for the full. I don't care about the two sub software as I only have one. The room is only 11 x 12.
If dealers were competent and could demonstrate what I am missing, then I can lay out a couple bills, but not sight unseen/unheard and for sure not taking their word for any of it. I thought I was buying new L, R, C speakers, but in hauling mine around, mine are still better than any I can afford. ( SB, Seas, Dayton based)
Well, I am buying some HDMI cables from a reputable firm. Probably BlueJean. But I may buy a CableMart and cut one open to see if it is built to their advertised drawing. If so, I'll get them. So far, opened 4 cables and none were correct. Searching the WEB, I found several others who opened them up to find they were wrong.
