Now I wonder if it's possible to make distortion at 10khz to 0.0001% 10W 4ohm load.
Anyway, kudos for bringing the first "sane" RCA-out to XLR-in cable to market (that I know of). It really was about time. No idea why cable manufacturers have been showing precious little interest.
Mine arrived mid-week and I installed them Friday night and Saturday morning. I have to contact support as 1) the speakers pop when the muting circuit engages and disengages and 2) the 12V trigger doesn’t work consistently. If I try it out repeatedly it’ll work, but both times I listened for over an hour it didn’t work on power off. The first time I had to turn all three amps off separetaly, and the second time the second amp turned of the third. Disappointing.
As lovely as this amplifier is, and as impeccably engineered and well measuring as it is, I am also of the view that active speakers are the future. If I was to buy a new system (and my existing gear won't last forever) then I don't think I would go with passive speakers.
Why?Now I wonder if it's possible to make distortion at 10khz to 0.0001% 10W 4ohm load.
The harmonic distortion of a 10kHz tone is all inaudible, except, arguably, the second.
Distortion at 100 Hz would affect all the harmonics of a most instruments, 10 kHz is already above the fundamental of the huge majority, if not all, musical instruments so of no interest whatever for music listening IMHO.
Yup, but he didn’t mention IMD or an 11 kHz tone.A system that exhibits harmonic distortion will also exhibit IMD if multiple tones are present, though. Some of the IMD products are lower in frequency than any of the tones in the input signal. You might not hear the 20+ kHz harmonic distortion on a 10 kHz pure tone, but you might hear the 1 kHz IMD product from a 10 kHz and 11 kHz dual tone if it's loud enough.
I show that in my THD+N versus frequency:I would like to see harmonic distortion measured at a frequency below mains frequency, say 40Hz here like HiFi News in the 1970s, to include power supply shortcomings, if any.
The almost vertical dark green lines on the left hand side, is that showing the amp cannot do high output at low frequencies?I show that in my THD+N versus frequency:
It can't after a while. The protection circuits monitors conditions and makes a prediction after a while and shuts things down. I am not sure but I suspect if I started the sweep from left to right, it may pass it (current sweep is from right to left so the amp has been running at full power for a while).The almost vertical dark green lines on the left hand side, is that showing the amp cannot do high output at low frequencies?
Give us a call at 1-800-BNCHMRK and we will get this sorted out for you.Mine arrived mid-week and I installed them Friday night and Saturday morning. I have to contact support as 1) the speakers pop when the muting circuit engages and disengages and 2) the 12V trigger doesn’t work consistently. If I try it out repeatedly it’ll work, but both times I listened for over an hour it didn’t work on power off. The first time I had to turn all three amps off separetaly, and the second time the second amp turned of the third. Disappointing.
The protection circuits detect full amplitude sine waves and limit the amount of time these signals can be produced when driving a low impedance. The time limit is a function of output voltage and output current. @amirm may be able to tell us the total sweep time before shutdown. He is correct: If the sweep was from low frequency to high frequency, the protection would have activated on the high-frequency side of the graph. A faster sweep time would allow a complete sweep before triggering the protection. Music cannot activate this protection mode. It just protects the amplifier from test bench abuse.It can't after a while. The protection circuits monitors conditions and makes a prediction after a while and shuts things down. I am not sure but I suspect if I started the sweep from left to right, it may pass it (current sweep is from right to left so the amp has been running at full power for a while).
As you have suggested, the frequency response variations are much too small to be significant. You would discover much larger variations between the left and right speakers and between speaker samples. You would also discover larger variations by moving you listening location by an inch or two. I would be more inclined to look at THD differences and phase response differences.
I will say that I like the numeric calculations that you have made to combine the speaker data with the amplifier data to predict the system frequency response - nice work!
At levels where transducer distortion will be high enough to mask amplifier distortion, the transducer will also be creating new non linear distortions based on any non linear distortions in the signal chain--in effect amplifying the problems in the amplifier (or other device). At levels where the transducer is introducing fewer distortions, any masking effect will be less significant. Unfortunately measuring this at the loudspeaker end is very difficult for most of us, due to microphone capability and environmental noise.So of course whatever problem in the amplifier is masked by the transducer.
This figure you give for the amplifier equivalent impedance--is this simply the real (resistive) part of the complex impedance? That's what it looks like based on punching those numbers into an impedance file and entering it into DATS, but i want to make sure I'm not missing anything.From the amplifiers perspective, -45 degrees at 4 Ohms is equivalent to driving a 2.8-Ohm resistive load. [...] -50 degrees at 4.1 Ohms is equivalent to driving a 2.6-Ohm resistive load.
For those whose eyes may have had a problem reading @dkfan9 highly relevant fine print.
This is the most straightforward laying out of the equations I've found, given the magnitude and phase. Thank you!4 ohms at -45 deg = 2.83 ohms + j2.83 ohms -- real and imaginary parts of the impedance, yes (j = sqrt(-1)).
A angB = A cosB + j*A*sinB = x + jy
A = sqrt(x^2 + y^2), B = arctan(y/x)
