There are two potential problems. One is the sub revealing its location. The other is with destructive interference ("phase cancellation") between the wavefronts from the main speakers and the wavefront from the sub for listeners that are off to one side far enough for the two distances (the distance to the sub and the distance to either main speaker) to differ by a half-wavelength. At 300 Hz a half-wavelength is 3.75 feet.
105dB from what distance? If you sit 2m from the speakers then you need 111dB at 1m to get the 105dB at 2m, at 4m you need 117dB at 1m and so on. Double the distance and the SPL drops by 6dB.
Those are test tone audibility thresholds; the 20% was for audibility with “content” playing.
I got a deal on M106's, 1200 euro for a pair (imported from the UK). But that was after 2 months of looking for sales, they never go on sale in Europe. F36's are 1200 euro's a piece. F206 2000 euro's a piece. I asked for discounts on the M106 at a Dutch dealer, and the most they could give was 10% on MSRP. So its basically more a case of finding good deals on them, but its virtually impossible in Europe to get them.
I got a single SB2000 right now, looking for a second.
Indeed, and you're supposed to localize them in such a system (if you could (equal loudness contour). As mentioned, most three ways (and the 4 way [Thanks Ron!] Salon2 interestingly enough) already do this. We're not talking about subs that you'd place in some random corner, they need to be on the same plane as the bookshelves in question. If you run HT, you'll need an additional pair of 12 or 15s (or greater) to do it right.
AFA cancellation, if you run/xover your subs up to your bookshelves in any fashion, you'll always run this risk if care isn't taken in optimizing phase.
In the end, I'd really like to see the next review of a bookshelf to contain a comparison using various hi-pass crossover points and slopes, to determine how much they improve performance, especially in the area of distortion. However, given the relief the midrange would receive, I'd imagine that everything aspect would improve. Localization of the sub below it would be welcome, but optimized.
Build quality, I was expecting it to be more solid. It weighs less than a single one of the monitors I used before I got the M106. I think this sub would benefit a lot from a more solid enclosure. I've put a big potted plant on top of it to make it resonate a bit less.I am envious of the SB2000. Have you found anything about it that you're less than happy with?
Very unlikely, you almost never have a single note playing in a song, equally one or narrow bandwidth. But yes, this is why 90dB DACs don’t get a recommendation from Amir even though its more than enough for 99% of musical content.What if the "content" sounds a lot like test tones?
It comes from some human audibility studies or ”musings” that I have seen. This is why 1% THD is used for clipping in many specifications, as that’s around the audible threshold with content playing in the treble. Thankfully nowadays many are transitioning to 0.1% or lower.Well, I suppose I must have missed something. You posted a table that indicated that the threshold of audibility for harmonic distortion at 100 Hz is between one and two orders of magnitude lower than you said it is, i.e., between .2% and 2% depending on the loudness and the order of the harmonic component, vs. the 20% you stated. This was conspicuous, but no one pointed it out, so I did. Subsequently you explained that the true value is much greater than the values in the table because the values in the table apply only to test tones as opposed to real content. This leaves me wanting to ask two questions. First, why did you bother to post the table given that you were going to end up arguing that the numbers in the table have no meaningful bearing on the actual threshold for real content? Second, where did you come up with the 20% figure? Does it involve some well-defined and well-researched algorithm applied to the numbers in the table, or does it come from somewhere else entirely?
Yes, by more solid I mean just more mass. I can feel it resonating pretty hard, until I put something on top.Interesting. According to SVS spec it weighs 39 lbs. The most stable subs are probably the ones with a single downward-facing driver and dual opposing passive radiators. A more solid enclosure might have some benefits but wouldn't keep it from wanting to scoot around except by virtue of the added mass, and the big potted plant you put on top of it seems a very good way to take care of that. Now I'm going to have to add a big heavy potted plant to my wish list for audio gear.
Don't compromise...just get a Rythmik. Plant optional.Interesting. According to SVS spec it weighs 39 lbs. The most stable subs are probably the ones with a single downward-facing driver and dual opposing passive radiators. A more solid enclosure might have some benefits but wouldn't keep it from wanting to scoot around except by virtue of the added mass, and the big potted plant you put on top of it seems a very good way to take care of that. Now I'm going to have to add a big heavy potted plant to my wish list for audio gear.
Subjective comparison of the M106 VS Focal Aria 906 at the end of this article:
https://www.soundstagehifi.com/index.php/equipment-reviews/768-focal-aria-906-loudspeakers
I guess that reviewer prefers that kind of sound.Subjective comparison of the M106 VS Focal Aria 906 at the end of this article:
I also own 4 way JBL 250ti which I think weigh around 130lb each which have 15 inch woofers in them .
