Perfect no, theoretically a good vertical radiation is possible with D'Appolito (DA) concept, as has already been said, it depends on the driver spacing (M-T as well as M-M) and the crossover concept to control the vertical radiation lobes.@ctrl is it possible to perfectly control vertical radiation (while keeping horizontal radiation wide) with such designs? Or do we always end up with inconsistencies?
In the original DA concept, the distance between the centers of the midrange drivers must not exceed 2*lambda/3 of the crossover frequency when using a third order crossover.
Then you get only one main lobe in vertical direction without side lobes.
Only very few driver combinations can comply with this. In the case of the Nubert nuvero 170 mentioned above, this would be a midrange to tweeter crossover frequency of 1000Hz.
To control the horizontal radiation, it hardly matters whether an M-T-M or M-M-T concept is used - but an LS radiates not only horizontally or vertically, but also in between ("diagonally"), so in theory symmetrical concepts have advantages.
In reality, one tries to use a D'Appolito (DA) or a multiple DA concept (W-M-T-M-W) to take advantage of the disadvantages due to the vertical driver to driver interference to keep the vertical radiation narrow and accepts the comb filter effects of the midrange driver to driver interference for this.
How even or uneven the vertical radiation is in the case of the Nuvero 170 is difficult to estimate. The frequency responses could look pretty wild at larger vertical measurement angles, but at low frequencies it becomes easier to meet the "DA distance rule".
To give a practical example....
My next but one project (should I ever have time for it) uses a DA array to force a very tight vertical dispersion. For this I accept comb filter effects in the vertical radiation. Unfortunately, there are also a few side lobes in the vertical radiation.
In return, an LS with +-90° horizontal and +-30° (-6dB limit) vertical dispersion can be realized. On average, this results in a loudspeaker with very even radiation, even if the details are not perfect at all. The crossover frequency to the tweeter is 3kHz.
