About 15 years ago I recall seeing a pair of B&W 801 speakers that were disassembled and arranged so that the tweeters were pretty close together in front of the listener, the mids were out at about the normal 60 degree triangle position, and the woofers were way out wide, to either side of the listener. This had been set up somewhere as a demo, with some explanation that the lower frequencies required more separation to achieve a similar stereo effect. I may have some details wrong but I recall the picture with a young woman sitting in the listening chair and the drivers all separated around her.
Since seeing that, I've not seen more about that kind of arrangement. I experimented with it and found it very intriguing sounding, creating an illusion of sounds actually occurring in the room in a way they simply would not when all the drivers were stacked up on top of each other in the usual, sensible arrangement. Now, through happenstance I'm back to that arrangement to some degree, with my bookshelf speakers fairly close together, but crossed over at 300hz to corner horns that are out in the corners. I normally run this in a 3 speaker up-mix for the bookshelves to create some crosstalk reduction that widens the stereo sound stage and solidifies the center image. Out of curiosity I decided to turn off the center speaker up-mixing and listen to the setup in regular stereo. To my surprise, it continued to produce a wide soundstage, with clear high tones seeming to be coming from well beyond the bookshelf speakers. The little speakers were doing a fine disappearing act. I also tried running R.A.C.E. through the stereo setup to actively reduce crosstalk. It widened the soundstage more to like what I hear with my normal 3 speaker up-mix, but not a whole lot wider than the straight stereo arrangement was creating.
So, it seems there still is something compelling I'm hearing with the horizontal arrangement of high and low frequency drivers, spread apart at considerable distances. This is definitely not a point source, and would be a real bear to qualify using the speaker testing method popular on this site. I guess you could measure each driver/cabinet separately and add everything up somehow.
Has anybody else read about this configuration, or tried it? Is there a particular name for it?
