PreSonus Eris E3.5 Powered Monitor Review ($100/pair)
khark
The Old World
Wonder if there is something that measures somewhat "acceptable" below the JBL305 pricepoint. Interesting subject.
sweetchaos
The Curator
BC, Canada
richard12511
khark
The Old World
I'm not following your train of thought...
We have several well-measuring speakers below US$300/pair (measured by Amir):
- KRK Classic 5
- Kali LP-6
- Fostex PM.03
- Fluid Audio FX50
- Edifier R1280T
Not to mention active speakers that Erin reviewed as well.
The 305 pair currently sells below KRK G4/T5V/LP6/FX50 prices, at least in Europe.
The Fostex PM.03 seems to be a better choice than the Presonus 3.5 based on its measurements and not much higher price.
AnalogSteph
.de
Wow, that’s a terrible spin. But I do wonder, perhaps the scoop out of the low-mids is intentional to compensate for their intended placement as a computer speaker, sitting directly on a desk below or to the sides of a monitor. The acoustic reflections off the desk from such a placement would boost the low mids quite a lot, but not enough to make it tonally neutral I’d guess. Doesn’t address the bump at 100 Hz either but that’s a popular tuning for these types of product.
Yeah, an on-desk measurement would definitely be interesting here, though things do look rather extreme. I got a pair of these as projector speakers for a colleague, and thought they sounded decent-ish with some tone control adjustments, though the issues in the vertical were definitely noticeable. A single-capacitor crossover no doubt, much like the E4.5 (for which this is much more out of place). Shame 'cause basic dispersion appears to be quite good. A better XO would no doubt help.
hardisj
hardisj
Reviewer
North Alabama
In my Kali IN-5 review, I tested what their DSP settings did for the response. Assuming those guys did their homework and the DSP settings match what one would actually get if they put the speaker against a wall, on a console, etc then we can use that as an indicator of what to expect if we placed a speaker on the desk. In which case, it wouldn't fix this significant trough in response.
Savi
For information I run 3 REW stepped sine measurements with umik and Eris 4.5 (umik at 25cm from the tweeter) at low spl (around 75 db @ 25cm).
Orange --> LFpot = 0db & HFpot = 0db
Red --> LFpot = 0db & HFpot = -3db
Blue --> LFpot = -3db & HFpot = -3db
bennybbbx
germany
The FR is really not good, but can correct. I think this speakers when correct with EQ sound best i have in stereo width. today i open them and want try what happen when i disable the tweeter. I measure this with HF +6 db knob set and no other EQ use. Tweeter cable is cut. maybe i add switches, so i can switch tweeter on and off or choose diffrent capacitor for crossover 10 khz . They are really good wide band speakers too and can to go upto 15 khz - 6 db. when i see avatone mix cube FR or auratone they look not better. there FR spec seem 70-15 khz -10 db. thats worser as eris without tweeter. the big peaks in eris at 1-2 khz stay in. the 8-9 kz can reduce when not exact on axis.
all is 1/3 smoothing 1 is on axis 2 is my hear position i guess 5-10 degree off axis
and here can see how the high tech crossover look :D:D. this can see when remove the woofer. the right speaker backplate is not removable.
the front plate can remove due to pull. need not hard pull
the amp is on left speaker and 2 signal cable go to right speaker. the tweeter is only coupled with a capacitor. so 6 db crossover and the woofer have no crossover.
I have done it today in the next time i do tests if wideband speaker really sound better in mid. maybe wide band speaker sound only better in mid when other have slow bass mid woofers that go only upto 5 khz. maybe most larger bass woofers only reach 6 khz but for ITD is more need.
If i find that wide band speakers really sound better, i maybe buy a Omnes Audio BB 3.5. this have good FR upto 18 khz. enough for me. https://www.oaudio.de/out/media/Datasheet_BB3_5.pdf this is in size 3.5 and can replace the eris woofer
bennybbbx
germany
PhantomFoxes
Before using an equalizer, it is essential to add a good crossover, I do not know in the Eris E3.5 but in the Eris E4.5 the old model did include a fairly well-made crossver, in the new model it totally loses the crossover by reduction cost and adding one is equal between the difference between day and night, and it shows a lot
The 4.7 capacitor in the tweeter is fine, but adding a true crossover to the woofer turns garbage to gold.
Probably using equalizer without adding a crossover is to equalize the breakage of the woofer cone without further affecting the response of the tweeter.
It is not that the E3.5 and E4.5 models are bad, it is that they have made them bad by reducing costs
bennybbbx
germany
I have a pair ribbon tweeter monacor RBT 35SR. they can go low to 800 hz when not make loud. I test it with the eris an amp for the rbt 35 sr and the t.racks mini dsp. this dsp have 4 outputs 4 channels 7 eq per channel and each channel have a delay and high and lowpass crossover in many types. delay work in sample steps( 1 step is 1/48 khz) . i notice crossover freq and also 20 microseconds delay between tweeter and woofer change the sound due to FR and phase, but it did not help to give better stereo and room size on eris. only on the kali lp6 with the big 6.5 woofer stereo and width and room reproduction get better when i go lower as the 1,6 khz crossover the default for the lp6. all my tests with ribbon bring me only the result that a ribbon does too not help to get good stereo width as with wide band speakers
I soon get a JBL 104 . this have a 4.5 inch speaker and is coaxial with crossover 1725 hz. this is much lower as the eris (have 2.8 khz). when i compare this with the fullrange eris then i know if it is important to get correct stereo width and room reproducion that only fullrange speaker are good. maybe a coaxial system work too or not. this my tests then show.
here is explain how hear stereo and there is a audio example wav to test if you can hear ITD. it is from simon fraser university.
https://www.sfu.ca/sonic-studio-webdav/handbook/Binaural_Hearing.html
https://www.sciencedirect.com/topics/medicine-and-dentistry/binaural-hearing
Binaural hearing uses two main acoustic cues: interaural time difference (ITD) and interaural level difference (ILD) (Doerbecker and Ernst, 1996; Francart et al., 2011): • ITD is the delay between both ears. It is efficient for low frequencies (below 850 Hz). It is due to the envelope of the signal reaching the two ears. It can be reminded that a sound coming from the side at 90° has an ITD of 0.6 ms. When the source is situated in the front (azimuth 0°), the so-called front target, the ITD is 0 ms. • ILD is related to the intensity reaching the two ears. The signal is more or less attenuated by the head shadow. This effect is mostly perceptible with high frequencies (above 3 kHz). ILD is 0 for the front target.
a period time of 1 ms is 1 khz frequency. humans are able in tests to hear 0.01- 0.02 miliseconds delay diffrence between speaker. thats less than 1/ 44.1 khz sample
When hear at low volume the level diffrence between left and right ears are very few so this seem another reason that records sound on speakers so much better when hear loud. It is possible for the brain( seem not all people) to create on lower frequency the direction depend on phase. in every music records is a nice sounding room or hall reverb add because it sound better in a concert hall than in bathroom This seem the reason wy wide band speaker on low volumes also give an amazing sound and correct stereo width. when can hear at low volume and get amazing sound and room feeling save ears and the neighbours like more.
PhantomFoxes
Have you continued testing?
I'm sorry. I didn't understand your answer the first time
I understood what you want to achieve in such an absurd way and yes, the speakers in the Eris are quite closed. I was playing with a smartphone, nothing special until I decided to put on a song, the stereo dispersion is so great that I keep wondering how it is that such a small thing can sound so open.
Then. I listened the Presonus Sceptre monitors and there I understood everything
It's one thing for the speakers to have a flat response frequency, and another for stereo dispersion.
But how to achieve both with DIY?
Something, I would like to try the Faital Pro 6HX150 or the Beyma 5CX200Fe, I know they are not hi-fi speakers but, it would be interesting to know if something similar can be achieved, it would not be so farfetched, many current consumer monitors use amplifiers with dsp to equalize the speaker curves
bennybbbx
germany
If you want do DIY on larger speaker, i suggest put a wide band speaker in the box you have(maybe 6 inch or 8 inch) that can reach 20 khz and use the old tweeter. I am 99.9% sure this give good stereo width.
I have changed the eris 3.5 to work as a wide band speaker, because the bass have no crossover there need only disable the tweeter. the eris bass/mid can reach around 12 khz much more as larger speakers can do. it sound a little better in stereo but in high freq is loss that can not correct. with EQ also on 50 cm away the high frequency loss depend on head position is much..I have now the jBL 104 (newer BT is important because this have not the 7 khz gap as the older)and this sound even more better. here are results of the JBL 104 in JBL 104 thread https://www.audiosciencereview.com/...wered-monitor-review.11076/page-7#post-895287
the jbl 104 BT is best i hear in my life in stereo width. It is acoaxial system and can put close.if sound quality enhance is even more possible to hear for me i am not sure.
correct stereo width have nothing to do with speaker dispersion. speaker dispersion help of course when you have a large room that sound good that you get a additional reverb from your room. but thats of course not the real room that is recordet. the most realistic sound can get only when speakers are very near and woofer/ mid range can reach at least 12 khz (as the eris 3.5 do).
the iloud mtm i sell but the eris 3.5 i have keep as secondary speaker wide range without tweeter
mcfingrs
...Erin's and Amir's work creates a yardstick or baseline on what you should expect and what is available at a given price point.
Not being an audio purist (though I dabble in recording and own a Presonus audio interface). I just wanted to appreciate Spotify streaming without the RFI from my cell phone. After searching through all the crap on Amazon, I decided to try the 3.5s because they're powered, small enough to fit behind my monitors (on stands, against the wall and about 60-degrees off-axis) and still cost less than any of the crappy Creative 2.1 desktop systems and knock-offs... very pleased that they reject RFI as that would have been a deal-breaker.
I found this site searching for "Eris 3.5 scoop" because they're boomy and seemed lacking in mids. The write-up and charts were very helpful (if maybe a little TMI for me), but skipping to the Parting / Random Thoughts was perfect. Never would have thought to stuff the ports, but I like these speakers much more now. hardisj, hope my small donation wasn't insulting, but the speakers are only $100.
...But I do wonder, perhaps the scoop out of the low-mids is intentional to compensate for their intended placement as a computer speaker, sitting directly on a desk below or to the sides of a monitor. The acoustic reflections off the desk from such a placement would boost the low mids quite a lot, but not enough to make it tonally neutral I’d guess. Doesn’t address the bump at 100 Hz either but that’s a popular tuning for these types of product.
IMO, Bose ruined consumer audio. Their engineering is impressive, but now bass hype is the single standard for most consumers.
To add my own 2¢review as an actual owner, after reading the thread I don't understand the harsh responses for $100 powered monitors.
These checked all the boxes for computer speakers: cheap, compact with sufficient low-end, self-powered and reject RFI. I would gladly purchase these again (and stuff the ports). No regrets. If this wasn't a company-provided locked-down laptop I would play with some DSP EQ.
I wouldn't mix on them, but I think they're a great playback comparison source and typical of what consumers would hear.
antikryst
i have this too. using them as computer speakers and as gaming speakers. i dont see anything wrong with them and i am really happy with it. but when i want to listen to music i whip out headphones.
antikryst
you stuffed the ports? polyfill? how much? LOL. did you stuff them all the way inside to the point where you cant remove the polyfill anymore?
i may have some polyfill somewhere at home.
Steve Dallas
A Whole Other Country
Roll up a black hand towel or washcloth or two and stuff it tightly in the port to turn it into a sealed box. This is not a job for Polyfill.
yigitboy
Turkey
Full review at my site:
https://www.erinsaudiocorner.com/loudspeakers/presonus_eris_e3_5/
  • Friday, May 14, 2021
However, for those who want more - a detailed explanation of the objective performance, and my subjective evaluation (what I heard, what I liked, etc.) - please watch the below video where I go more in-depth.
<< coming soon >>
Information and Photos
PreSonus’s Eris E3.5 is a compact powered 2-way speaker featuring a 3-inch mid/woofer and 1-inch dome tweeter. At only $100/pair, they are one of the best-selling “budget” monitor speakers. They feature a stereo 1/8-inch input, Balanced TRS and Unbalanced RCA inputs. The Eris also features both a low-frequency and high-frequency trim to allow you to tailor the sound as needed. The below is from the manufacturer’s website:
PreSonus® Eris-series studio monitors are used worldwide by audio engineers who need to hear every detail of their recordings. Ideal for gaming and home video production, the Eris E3.5 employs the same technology as the larger Eris models to deliver studio-quality sound, with a smooth and accurate frequency response. Yet they’re compact enough to fit almost anywhere.
MSRP is about $100 USD for a pair.
The reference plane in this test is the tweeter. A single RCA input was used and the volume was set to about 3/4 max. The port was open (not stuffed). All settings were at default (0; no HF or LF adjustments were made).
CTA-2034 / SPINORAMA:
Early Reflections Breakout:
Estimated In-Room Response:
Additional Measurements
On-Axis Response Linearity
“Globe” Plots
Vertical Polar (Globe) Plot:
Harmonic Distortion
Near-Field Response
Nearfield response of individual drive units:
  2. 86dB at 1 meter (red)
  3. 96dB at 1 meter (blue)
  4. 102dB at 1 meter (purple)
Based on my results above, it is obvious the output is strictly limited. These are not designed to play with a lot of output and instead are best used as computer speakers at moderate volume levels.
Long Term Compression Tests
  • Subjective listening varied between 0.50 to 2 meters. Subjective listening was conducted at 80-95dB at these distances. Higher volumes were done simply to test the output capability in case one wants to try to sit further away.
As is, with no tonal adjustments made via the knobs on the back of the speaker, you have an extreme “smiley face” or “v-curve” response with a peaky midbass around 100Hz and a very bright sounding treble. The midrange is very recessed and the enclosure is the source of strong resonances. Certainly not something I would consider useful in mixing or monitoring as the ideal response for those situations should obviously be an uncolored, neutral (flat) speaker response on-axis.
After fiddling with the settings, listening and running the NFS tests a few more times, I ultimately found this setup offers the best compromise:
  1. Stuff the ports. Yes, I know you want the speakers to get lower but the ports only serve to mess up the response. You can use a shirt, small dish towel… whatever plugs up the port.
  2. Set the HF to “-6dB”.
  3. Set the LF to “+3dB”.
While still not ideal, this gives a more linear response without significant peaking in the midbass and overaccentuated highs. Doing so yields the following SPIN results:
CEA-2034%20--%20Presonus%20Eris%20E3.5%20%28Port%20Stuffed%2C%20HF-6dB%2C%20LF%2B3dB%29.png
You may be trying to choose between these speakers and the Mackie CRX-3 I have also reviewed. They each have their own issues. My suggestion as to which to buy boils down to this:
  • No matter what speaker you buy STUFF THE PORT. It doesn’t help you get any lower. In fact, it only serves to provide a resonant bump ~ 100Hz and results in a steeper roll off.
  • If you don’t plan to adjust tonal balance knobs on the PreSonus then get the Mackie. Easy choice.
  • I think it is a coin toss between the Mackie CR3-X and the adjusted PreSonus E3.5. Though, I’d probably leave toward the Mackie as it still has a more neutral response (especially with the port stuffed).
  • If you are placing these near a wall the PreSonus’ tonal controls may prove useful enough (by lowering the boosted bass as you put the speaker near a wall) and make the decision to go that route easier. Though, I would recommend turning the speakers off axis; otherwise the treble is too much. 30° to 40° looks to be the best compromise. Still, the Mackie’s HF balance appears better when the same positioning is used for that speaker.
You can view a comparison of the on-axis response between the two speakers below.
However, if you adjust the Eris E3.5’s tonal balance controls and port stuffing as I had recommended then this is the comparison:
As with anything else, I suggest purchasing these from a retailer who offers a return policy so you can try these out in-home. If you’re in search of such a retailer, please consider using my B&H affiliate link below.
As stated in the Foreword, this written review is purposely a cliff’s notes version. For more details about the performance (objectively and subjectively) please watch the YouTube video.
DSP Suggestions
If you have the means, I recommend using EQ to help flatten out the response and achieve a more neutral response, as a set of monitor speakers should provide. Doing so will help immensely and is necessary in my humble opinion. I have provided two examples created via REW software’s auto-EQ program based on a standard miniDSP. They are provided in a screenshot below. If you need help understanding how to use these, I encourage you to check out NoAudiophile’s page here which also has other DSP suggestions for various speakers. It is a great resource for this type of thing.
  1. DSP Suggestion for the “out of the box” response:
  2. DSP Suggestion using my recommended settings (port stuffed, HF/LF trim enabled for -6dB/+3dB, respectively):
You’ll probably have to increase the photo size to see the individual settings.
Support / Contribute
If you like what you see here and want to help me keep it going, please consider donating via PayPal here. Donations help me pay for new items to test, hardware, miscellaneous items and costs of the site’s server space and bandwidth. All of which I otherwise pay out of pocket. So, if you can help chip in a few bucks, know that it is very much appreciated. Alternatively, if you are interested in purchasing these speakers, please consider using my B&H affiliate link found on my site. It yields me a small commission at no additional cost to you and allows me to keep doing what I am doing.
You can also join my Facebook and YouTube pages if you would like to follow along with updates.
I have a Temblor T8 Subwoofer addition to eris 3.5s. Should i ignore eq for low freq
Thinkingman
Is it better to buy the wired Presonus 3.5 or the Presonus Bluetooth version. I use it only for my desktop monitor. Not involved in any professional audio work
