So disappointing!
The Neumi is a better buy, lol.
Success! Making the world a little better (sounding)Neumi listened and have made adjustments.
If Erin had a headless panther these would have earned it. nicely done. Hopefully this convinces a few people looking to buy their first "real speakers" on a budget to save their money and be patient.
The second, labelled Erin is his EQ with the default settings i.e. no tweaks.
Score EQ Erin: 4.9
And the Presonus Eris 4.5? Are better?
lower price=more sales.For many years this has been either the #1 or #2 selling powered monitor in both US and European Amazons. Yikes.
True. And it's #2 at Thomann too currently. I guess at this price point one should not have unreasonable expectations.
Quite decent after EQ! This should be called "extreme makeover" lol.Hi,
Here is my take on the EQ.
The raw data with corrected ER and PIR:
Score no EQ: -1.3
With Sub: 4.3
Spinorama with no EQ:
- Not as Flat as i would expect, maybe because the multimedia usage?
- Pretty bad
- Ok Horizontal Directivity
Directivity:
Better stay at tweeter height
Horizontally, better toe-in the speakers by 10/20deg and have the axis crossing in front of the listening location, might help dosing the upper range.
EQ design:
I have generated two EQs. The APO config files are attached.
- The first one, labelled, LW is targeted at making the LW flat
- The second, labelled Erin is his EQ with the default settings i.e. no tweaks.
- The EQs are designed in the context of regular stereo use i.e. domestic environment, no warranty is provided for a near field use in a studio environment although the LW might be better suited for this purpose, probably in the near field so no Score EQ this time (I checked it would be very close to the LW anyways)
Score EQ LW: 5.8
with sub: 8.3
Score EQ Erin: 4.9
with sub: 7.4
Code:Presonus Eris E3.5 APO EQ LW 96000Hz May162021-123909 Preamp: -0.1 dB Filter 1: ON HPQ Fc 54.6 Hz Gain 0 dB Q 1.24 Filter 2: ON PK Fc 107.9 Hz Gain -9.95 dB Q 1.5 Filter 3: ON PK Fc 1037 Hz Gain -4.3 dB Q 1.51 Filter 4: ON PK Fc 1654 Hz Gain -7.05 dB Q 4.13 Filter 5: ON PK Fc 3382 Hz Gain -5.5 dB Q 1 Filter 6: ON PK Fc 6494 Hz Gain -1.77 dB Q 2.42 Filter 7: ON PK Fc 9160 Hz Gain -8 dB Q 0.73 Filter 8: ON PK Fc 17116 Hz Gain -5.56 dB Q 4
Spinorama EQ LW
Spinorama EQ Erin
Zoom PIR-LW-ON
Does the EQ score take into account the distortion limits of these speakers? I suspect boosting these things at all creates too much distortion very quickly.Quite decent after EQ! This should be called "extreme makeover" lol.
For 100 bucks the EQ saved the day, now please the user should not listen loud.Does the EQ score take into account the distortion limits of these speakers? I suspect boosting these things at all creates too much distortion very quickly.
I have the 4.5 to listen radio with bluetooth in my kitchen and even if I did not measure it, my feeling is that they are pretty much as bad as Erin 3.5 measurements. For the price (175euros) I was really desappointed even if this works fine for my use.And the Presonus Eris 4.5? Are better?
