New 28-bit DAC coming out.
GXAlan
This came across my Facebook feed. It's a company based in California that's claiming 28-bit true performance. The link just leads to a landing page with a few quotes from professional engineers. The fact they are announcing/showing it at AES instead of launching it at an audiophile show suggests that it's really backed by science. I hope they consider sending one to @amirm
130 dB SNR is somewhere between 21 (126) and 22 (132) bits. 28 bits would be 168 dB.
Or somebody is playing with numbers, or my maths are really rusted.
Doing some internet sleuthing. It’s John La Grou’s company.
John La Grou is founder and chair of POW-R, the world's leading audio bit-length reduction algorithms. Roughly one-third of all CD and downloaded music is processed with POW-R. He is also founder and CEO of Millennia Media, a design leader in critical audio recording, live sound, postproduction, mastering, and archiving. Millennia is the world's most popular front-end for film scoring and classical music recording, while Millennia's phono preamplifiers are used by the Library of Congress to archive their collection of three million historic audio recordings.
Not likely to DIY :-) E.g.
Those patents are owned by Millenia, so that’s legit instead of being a no name company.
Their pro gear isn’t crazy priced
But they do have a $14.5K phono stage!
LOC’s front-end phono stage is based on the HV-3 double-balanced preamplifier used for recording nearly half of all Hollywood feature films scores (Titanic, Star Wars 1-3, Tarzan, Schindler’s List, Forrest Gump, Contact, AI, Armageddon, etc..). Leading acoustic music recording companies, such as Telarc, Sony Classical, Harmonia Mundi, DMP, Nimbus, Five-Four, Chesky, BMG, Koch, Klavier, and scores of others rely on HV-3 preamplifiers. The major symphony orchestras and operas of Los Angeles, San Francisco, Berlin, Cleveland, Seattle, Dallas, Israel, Prague, Baltimore, New York, and National (DC) employ HV-3 preamps, as do scores of others. Top live performers like Barbra Streisand, Celine Dion, Andrea Bocelli, Rolling Stones, and Bruce Springsteen use hundreds of HV-3 preamp channels in concert, as do the Academy Awards and other top global broadcasts.
Someone needs to get the company to send one to @amirm!
Super cool! It went from vaporware to likely shipping this year!
This is what it is doing.
I find the claim of 27 bits or 162 dB of dynamic range a bit misleading after having read Jan Didden's article in AudioXpress, where the whole system is described.
J.D. explains that the upper (7 bits) path and the lower path are only combined if the predicted output signal level reach a threshold above -26 dBu analog. From that threshold onward, the combined theoretical analog noise floor after the summing point is no better than the analog noise floor of the least good path, ie the analog noise floor of the "high path", which is -106 dBu (presummably over a 20 kHz audio bandwidth) from the text.
Hence, my belief is that if the signal barely reaches -26 dBu, the available signal-to-noise ratio at that level would be just 80 dB.
Even if the exact threshold and noise levels of a particular implementation would be different that the figures quoted by J.D., the logic of the system would remain the same.
So, what happens is signal dependent noise floor modulation. The rational behind that trade-off is, according to J.D., that noise is masked by sufficiently high signal, thus subjectively non-intrusive.
OK. Fine. That makes sense.
But I fail to see what purpose this system is intended to achieve beyond the possibility to claim to make use of all the 32 nowadays available bits in the digital domain.
What enjoyable musical sound needs 162 dB dynamic range? Here I like to quote Prof. Jamie Angus, who said about that very topic that we are no longer dealing with sound, but rather explosion, and more particularly the effect of thermobaric munitions.
Since it’s targeted at music production, I suspect it is for the convenience of recording. Taiko drums hit 120 dB at 5 meters, so if you are trying to mic the drum more closely, maybe you would want to have more dynamic range esp if it’s a mix of taiko drum and something else.
Sooo... if the maximum SPL peaks my ears can shortly tolerate = 125dB SPL and a 0dB sound pressure can only be detected when having acclimated in an acoustically dead room why would one need a DAC that can do 162dB dynamic range ?
What amp can match that ?
How many recordings actually have a S/N ratio >120dB anyway ?
It's just a numbers game and has no benefit to audio.
How many recordings actually have a S/N ration >120dB anyway ?
My crystal ball shows me people listening to it with speakers that compress as early as 100dB and claim divine improved SQ,just like with the ones changing from a 115dB SINAD DAC to a 120dB one :p
This doesn't excite me but I don't see how it's a bad thing (if/when it becomes economical).
Zoom makes some 32-bit floating-point ADCs and I WONDER if floating-point DACs are coming?
As far as I know, Zoom doesn't publish the digital headroom/clipping-point but (as expected) the nose-limited dynamic range is less than 24-bits. (They specify an EIN of -127dBu.)
Those interested can read this short AES presentation by Mr La Grou :
It is from this paper that Jan Didden took his numerical examples in his AudioXpress article. Those figures are thus La Grou's own when describing his systems. Mr La Grou effectively assumes a noise taken in the 20 Hz to 20 kHz bandwidth and a dynamic range from 77 nV RMS to 4.9 V RMS (or 6.9 V peak) at the analog output.
This seems like a convenience thing (listen to very low level signals in the studio by turning up the gain on the DAC instead of in the DAW for some reason) and/or a "because you can" thing, sort of like having a commuter sedan that can do 0-60 in 2.5 seconds.
If I'm not totally wrong the developer has been on here. I'll just have to find the thread(s) again....
EDIT:
Sounds impossible to be honest, must be close to some kind of theoretical limit for electronics at room temperature.
It's not impossible because a clever real-time range switching is done (actually, a cross-fade). Once the signal level is low enough, you switch to a heavily padded down output and re-adjust the digital input.
With ADC it's easier and it's been done for many years, if not decades. Any better guitar multi-effect pedal does this, these days.
The benefit of it is that you don't need to care about signal level ranges, Connect and forget. You can use one ADC and one DAC unit to cater for any signal from uV/mV range to several ten's of volts. For AC signal signals only, of course.
