Test CD for measurements of CD Players
"Show Clipping" option in Audacity shows clipping whenever a sample value: v >= MAX_AUDIO or v <= -MAX_AUDIO
MAX_AUDIO is defined as 1. - 1./(1<<15) which is 0.999969.
Thanks!
And 1 - 1/(2^15) = 0.99996948 ;)
I don't understand why I have 17.1 ENOB. :rolleyes: I've read somewhere I have to correct something, I don't remember where.
Magic of dither (self dither in this case in my understanding)?
We talked about it here.
You see 17.1bits here because REW uses the full formula and so accounts for the -17.91dBFS attenuation that I see at the input of your interface.
REW should be updated soon to allow us toggling on and off the full or simplified formula, so the ENOB will be correctly calculated in our case. That means the formula should assume that we measure full-scale input signal, and so should be:
With your measurement, the ENOB would be roughly 14.2 bits.
I hope it clarifies.
What is the procedure for capturing crosstalk measurements from CD?
I'd like to add these measurements to my previous efforts, and I think it will be highly relevant to my next set of measurements for a dual-DAC setup. Thx
Use files #17 and #18 for that purpose.
They are a sequence of 100Hz, 1kHz and 10kHz test tones.
File #17 has data in left channel only. So play it and measure the output of the right channel of the player. You will see 100Hz, 1kHz and 10kHz respective leakages, which is the crosstalk (should be very low, like below -90dB).
File #18 for the right to left channel crosstalk ;)
And one more 35 years old player that breaks the theoretical noise floor of CD Audio by more than 1 bit, thanks to the test CD to reveal it :p
Reactions: tpd
Specify »expensive« please, so that I could rest assure that my gear won’t be in danger :cool:
That is a highly variable amount (sometimes it's simply based on what someone is willing to spend on something): Example, I might be willing to spend a max of $7000 on a certain piece of new audio gear but I might be willing to spend a max of $50K on a certain used car.
