This is assuming MT48 will following Anubis functionality, as Music Mission in MT48 has some differences with Aunbis, I don't know what MT48's Monitor mission will be like.Monitor mission is foucs on multichannel Monitor.
Neumann don't know the conversion either?(But as I mentioned before, it's EQ is not same as REW, I'm trying to findout the formula) :
No, it's following the Anubis, and Anubis is following the Pyramix software's EQX, all from merging tech.Neumann don't know the conversion either?
There was discussion of a conversation factor of 4, but clearly this not trueNo, it's following the Anubis, and Anubis is following the Pyramix software's EQX, all from merging tech.
I can confirm is the Q value is affect by both gain and frequency, I get a estimation formula by measure loopback and calculate, but still with variant and small errors.
I recommend Neumann team to add the precise equation to REW since they recommend to use it with no MA1 speaker.
So, I had a Babyface Pro original. Just sold it. Was considering a RME Babyface Pro FS / UAD Twin X Quad / RME UCX 2.Replaced my RME Babyface Pro FS with the MT48 - been using it the last 4 weeks connected to my KH120ii. I love the intuitive onboard display, seamless connection plug-n-play to my Mac Studio M2. My only complaint - it gets hot compared to the Babyface Pro (which remains lukewarm at worst). In a smaller studio (10'x10'x9') like mine, you really need to have some air circulating out or A/C otherwise it warms up the room quicker than you expect. HIGHLY RECOMMENDED for Mac users.
I haven't had a chance to record on it yet, but music playback workflow is easier. That said, without thorough testing I cannot say it's better audibly. MT48 is definitely easier and has more complete i/o for me, and I definitely prefer the display! On paper it's "better" if that helps lolSo, I had a Babyface Pro original. Just sold it. Was considering a RME Babyface Pro FS / UAD Twin X Quad / RME UCX 2.
JUST stumbled onto the MT48. From what I can tell, it is superior to the UAD in terms of sound quality / clarity / conversion.
How does it (MT48) compare to the Babyface Pro FS, sonically? Is it noticeably better?
I’m an artist/writer, recording just vocals / acoustic / DI electric, bass, and keys.
Thanks so much!
John
Johnsierramusic.com
It would be nice to see the measurements of the MT48 at some time.
Diagram 13 suggests ESS IMD hump
You reckon? Not sure. I can see the teeniest bit in line out THD over level around -10 dBu though (diagram 9).Diagram 13 suggests ESS IMD hump
I am confidentYou reckon? Not sure.
I am using it for my movie composing studio. It will just connect to the Cubase running on a PC. I would also like to play Netflix and dolby surround on the same PC. The dealer mention something about the future possibility of using the MT48 headphone output for extra speakers but they are not too sure...As per the Quick Guide, the MT48 is suitable for 1 or 2 pairs of monitors, so the dealer is correct. There's obviously plenty of pros working with surround setups, so there has to be something to connect them to, but in this price class, no idea. What else do you need to connect?
Well, no news from Neumann despite two reminders...Hello
I currently have an MT48 audio interface and I'm really happy with it.
I'm going to restart my speakers with active filtration.
Filtration and equalization will be done on my computer which will be connected via USB to my MT48.
I will also need a subwoofer.
Question:
Can I connect my MT48 2x2 way and 1 subwoofer???
I made a diagram to be clearer.
Thank you for your answers
I also asked Neumann the question, I'm waiting for their response...
Hello
Question:
I also asked the question about a future update with Monitor Mission... Total silence!!!
Hello
Question:
