WaterFlame
Sorry, but I had to asnwer one last time.Where did I say to buy another amp? You claim, that you compared several ones.
How else do you want to compare amps unless you own them or have access to?
Again recording the output of each amp while attached to a speaker and running the result through Deltawave will tell you with much more certainty about audible differences than an error prone blind test. And if you don’t have the other amps anymore than record the one you have and obviously don’t run it through Delawave but simply post the FR and we can see if there is an audible load dependence. Plus you will have facts to post here and not anecdotes.
As it is very very doubtful that you heard differences btw all these amps you described but more likely have an error in your blind test (which once again is not even needed if you would have done what now several of us proposed multiple times). Do it right if you want to be taken seriously.
All seems like very weak excuses.
But I am wasting my time. I am out
I never mentioned that I wanted to test or share my blind tests. I was referring to already existing blind tests performed by Swedish LTS that are more robust than the tests I can do on my own, including your deltawave suggestion. You clearly did not study LTS in detail, otherwise you would have been very curious to understand how come quad 909, hegel, audioresearch and many others could not pass wire and gain test while Bryston passed. This would make you reconsider the dogma: "most amps that are not clipping sound the same".
As I mentioned, I no longer possess multiple amplifiers because I am happy with M23 for now also I have LS60w in another system that also was not cheap.
When I have multiple amps next time, I might do what you suggest but there are caveats:
1. obtaining a correctly calculated difference in deltawave is not walk in the park and most likely i will need to do blind test of recording with amp1 vs recording of ampt2 anyway
2. when listening to recordings, I will have to listen through my system. Those will go through my dac and amplifier again. I cannot guarantee that those are 100% transparent and will do nothing to the signal.
And of course, I would be running the test with preference scores and not with trying to correctly guess which amp is playing.
Found it much more discriminatory.
So I still believe a proper blind test rules.
p.s. anecdotal evidence can be informative sometimes
