Keith_W
Yes. I am on the beta program. What would you like to know?
Does it work for you?Yes. I am on the beta program. What would you like to know?
Get those KEF Blades 2 Metas we joked about.The answer is rather complex. The best brief answer I can give is: the concept is sound, the correction works as intended ... but this solution does not work for me.
I posted the result of my experiment in this post where I demonstrated @joentell's method indeed does correct the nearfield MMM to flat. However, it also produces a rising frequency response at the MLP. This is the opposite behaviour of any other speaker, where flat nearfield = falling Harman-like frequency response at the MLP. The reason why is because of the particular characteristic of my speaker, it has horns > 500Hz and a conventional woofer and subs below. Another experiment described in this post explains why my speakers behave this way.
BTW, when I did those experiments, I was not on the beta program. I was able to replicate the method based on the description of the concept. I posted a workflow for Acourate users earlier in the thread. The app automates the process a little and produces the target curve for you, but you do not need the app if you pay attention to the method and think about how to implement it in whatever DSP software you are using. A friend of mine got it working with Audiolense, but the problem with Audiolense is that it can not import target curves. Nor can it manipulate curves like you can in Acourate and REW. So he had to derive his target curve in REW, and then manually create a target curve in Audiolense using its target curve editor.
I still think this method is brilliant but it is a shame that my speaker characteristics prevents me from implementing it. If I get new speakers I will be sure to try it again.
Hi Keith,Yes. I am on the beta program. What would you like to know?
@Keith_W has a fully active 2.2 channel setup with lots of DSP and an atypical loudspeaker. It's one of the reasons I asked him to participate in the private beta testing.Hi Keith,
What is the speaker configuration?
7.2.4?
What Receiver do you use?
Audyssey or Dirac?
Is the imersiv sound bubble better than before?
KR Stefan
Hi Keith,
7.2.4?
Audyssey or Dirac?
KR Stefan
I would agree that timing and levels has more to do with immersion. Generally speaking, correcting speakers to have the same tonal balance can help with immersion if they are dissimilar. For example, if a constant sound pans around to other speakers and the tonality changes, it can take away from the experience. Tonal changes can be caused by different speakers being used, a speaker's distance from the listening position, and proximity to nearby surfaces or boundaries.Take a look at this thread for details about the system. I don't think the Magic Beans correction will change the nature of your immersive sound bubble, that is an issue of speaker timing and positioning. It will change the tonality to be more accurate, though.
I would love to do multi-sub in the future.I purchased this software today and tried it. The program was pretty simple to use and I was able to do it quickly. I don’t think I did the main listening position correctly so I am going to try it again this weekend. The bass seems neutered so I am going to have to kick that up. With all the said, initial listening seems good. Seems to have more clarity. I need to do a few good listening sessions before saying it was worth the money but I would say I am happy with it so far.
One thing that would make this amazing for dumb guys like me would be the addition of multi sub setup for a MiniDSP. That functionality would be the perfect addition.
Thanks for the response Joe! I will give that a shot. Hopefully get a another chance tomorrow afternoon after kids baseball. Tis the season!I would love to do multi-sub in the future.
Make sure to use the Post-EQ Sub Alignment feature in the app to set your sub levels. Don't rely on the room correction software to properly set that. Uncheck "lower by 10dB" and set your master volume so that the frequencies above 1kHz align with the yellow target. Make sure you have bass management on. Now, adjust your subwoofer volume so it also aligns with the yellow target response line.
Where do you buy this app?
