MMM result of the diminutive
Fluid FX50 coaxial speaker (centered on top of my front desk's computer screen) across different in-room listening locations:
View attachment 339235 View attachment 339236
SPL of all curves were auto-aligned with the ff. settings:
Speaker EQ was devised using
Amir's measurement data of this speaker and
my own listening judgment (room EQ in that post was meant for another listening position):
*However, I decided to discard the last 9 kHz PEQ
There isn't much of a difference going very nearfield vs my front desk's MLP since the change in distance is rather small.
Desk MLP distance from the speaker is ~0.7 meter while couch MLP ranges from 2.3 to 3 meters (averaged across the entire length of the couch).
Normally, there would be more variation seen in the bass response and transition zone across the room listening areas or seats if the measurement region is limited (or not averaged) -- more so if not using MMM and instead only single-point measurements:
View attachment 339238 View attachment 339239
*In this one particular case, a manually adjustable general low shelf filter for the bass is probably sufficient -- Yeah, I'm just lazy! This speaker is not to be installed permanently here, anyway.
